Originally Posted by Mattos M
When using the black tank cleaner should I have the black tank valve open? Ive been closing it and running the hose.
I think officially, leave it open. Saves you from the possibility that you’ll forget/walk away and end up overfilling the tank (either overflowing out the roof rupturing the tank).
However, I find that I can leave the valve open and flush for 10 minutes and the water runs clear. But if I then close the valve, let it fill, and then empty it- chunks and TP tend to flush out.
So for better tank flushing, I alternate.
But, I ALWAYS ALWAYS ALWAYS use a timer on my phone. ALWAYS.
