Old 03-25-2014, 08:12 AM   #1
Three drain valves on 317rl
I am new to this forum and have a new 317rl. First 5th wheel. My hookup panel has left to right, wastewater(one word), black label, white trim; sewer water, black label, white trim, and waste water (two words)' black label, no trim. The sewer is black water. Are the other two perhaps shower and galley, I. E. Two gray water tanks.
Ej
Ejwitman is offline   Reply With Quote
Old 03-25-2014, 08:16 AM   #2
iceblaze580's Avatar
Most likely one gray water is kitchen one is bathroom gray water best way to check is poor a few gallons down and see what valve dose what
iceblaze580 is offline   Reply With Quote
Old 03-25-2014, 08:22 AM   #3
Oakman's Avatar
Welcome to the Forest River Forum.
It helps to mention what brand fifth wheel you have along with the model number. Forest River currently has over 30 fifth wheel brands on the market.
I would imagine the valves are as you mentioned, Black tank, shower tank, and galley tank.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-25-2014, 12:22 PM   #4
It certainly sounds like you have two grey water tanks. What they do and how they are hooked up will depend on the model. In my case, one tank is for the outside galley, and the other is for the bathroom and inside galley. I have seen others that have all the sinks on one tanks, and the shower on another (I wish mone was this way). Looking at your floorplan, I am guessing the galley is hooked up to one, and the bath is hooked to the other.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 03-25-2014, 12:58 PM   #5
Fulltime family RVer
The thread title has 317RL and a Google search shows only Wildcat that seems to have that designator. It looks like this is your floorplan:
Given the spacing difference between the kitchen and shower AND that the specs indicate 100 gallons for the gray water capacity- it all adds up that you have 2 gray tanks.
ependydad is online now   Reply With Quote
Old 03-25-2014, 01:06 PM   #6
JAYCO Representative
Wildcat Chris's Avatar
The 317RL does indeed have 2 gray tanks split between galley and shower.
Wildcat Chris is offline   Reply With Quote
drain, valve
