Old 01-10-2013, 09:39 AM   #1
mjones12's Avatar
Tight gray water valve
Just recently the gray water valve on my three-year-old Surveyor has become extremely hard to pull. It's not that it pops free from being fully closed....the entire pull is hard, and it's hard to push back in to close it. Has anyone else experienced this, and what is the suggested fix? Perhaps WD40 on the shaft? Thanks.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 01-10-2013, 11:36 AM   #2
Twisty's Avatar
No WD 40 please.
This is copied from another source
"Remove the 4 bolts. Spread a bit and that whole piece... comes out. Clean it well, clean the inners and lubricate with plumbers grease and then reinstall. Should get it or you have to replace. Be sure to also lube the pull rod with silicone spray."
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 01-10-2013, 12:13 PM   #3
Herk7769's Avatar
Originally Posted by Twisty View Post
No WD 40 please.
Make sure it is totally empty and you have your nose plugs in place. Gray water tanks smell as bad as black tanks.
Old 01-10-2013, 12:21 PM   #4
I had a problem with my black water valve, last summer. It ended up being the cable. The gray water cable was replaced at the same time. It was the outer sheath of the cable that was cracked or broken.
Pipeman is offline   Reply With Quote
Old 01-10-2013, 12:55 PM   #5
mjones12's Avatar
Thanks to you all for the help.
