Old 06-23-2012, 11:07 AM   #11
Terier's Avatar
Originally Posted by VinceU View Post
I've owned them with a single stack but vents were Y connected(inside the interior wall ) in route to the roof. Without a vent, the tank would collapse when drained. Odors wouldn't change, but would be nasty if the common practice of forgetting the gray tank level resuls in common shower basin filling, I believe this one has two, there there just not sure how thy are plumbed. NO dwgs from FR.
What does "NO dwgs" mean?
Old 06-23-2012, 11:17 AM   #12
VinceU's Avatar
Blueprint authors/readers often shorten drawings to dwgs in text notes
Old 06-23-2012, 12:13 PM   #13
MtnGuy's Avatar
Originally Posted by chipshot View Post
Just purchased new 2010 rockwood mini lite from a bk dealer.
What is a bk dealer ?? If the unit is brand new, then you need to take the trailer back to the dealer and let Forest River fix the problems under warranty.
Old 06-23-2012, 10:20 PM   #14
tank issues
The dealer went belly up and the bank and a motorcycle dealer tryed running the store under a different name ,but shut down the operation,moved the inventory to the mc dealers lot and is selling the units off from there. Another rv dealing went thru the entire trailer and spent 2 days checking everything out He was physically under the trailer and found the cut wires and saw how the plumbing was run. I will pull the panel off the base of the shower and see if it has a trap installed and check the bathroom sink for one too. Both the shower and sink have stoppers that fit the drain so maybe I don`t have much of a issue except that the tank is going to fill up in a hurry and the grey tank which has only the kitchen sink hooked up to it might last all summer. More to come after checking these things out
chipshot is offline   Reply With Quote
Old 06-24-2012, 06:31 AM   #15
MtnGuy's Avatar
If the dealer went bankrupt, call Forest River and get them to refer you to another dealer to get the problem corrected.
Old 06-24-2012, 07:18 AM   #16
Not sure about your specific model, but I did have a TT which recycled grey water into use as toilet flushing water.......in other words, (not saying the guy knew or didnt know when he was looking) but this might be the case where he sees a grey line to the toilet....just a thought........that was the set up on my previous 28ft Springdale TT
Note: not sure on the mechanic that looked at it, was he/she was an RV one or a Motorcycle mechanic........
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
Old 06-25-2012, 07:36 PM   #17
Villa Estate 392FLFB
The_Stuff's Avatar
what MTNGUY said. CALL FR!!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-03-2012, 09:52 AM   #18
Just purchased new 2010 rockwood mini lite from a bk dealer. After having a different dealer check out the unit, he tells me that the toilet is dumping into the grey water tank and it was plumbed from the factory like that. Also all the wires for the tank monitors were cut under the trailer . this unit is brand new nothing was put together yet with plastic still on the bed . Was it unhappy soon to be laid off workers or bad engineering?
Was probably a factory worker having a bad day or hacked off at his boss or a new-hire. Since you've already accepted delivery, you need to have the dealer you took it contact FR to see how they want to proceed under warranty coverage. In other words, have the dealer handle it.
Be aware though that since this is a 2010 and purchased from a bankrupt dealer there is a distinct possiblity it doesn't have a warranty.
RonD430 is offline   Reply With Quote
Old 07-22-2012, 12:03 AM   #19
Question Holding Tanks...What Goes Where?
I have a 2003 Sunseeker. During the last camping trip, the black water began backing up into the toilet because the tank was full (of course the guage only indicated 2/3 full). Before I could go outside and open the valve to drain into the park's sewage system, I ran some water into the bathroom sink. The sink backed up and wouldn't drain until I emptied the black water tank. The grey water and galley tanks were not full when the black water backed up (They may each have been 1/4 full).
Does this indicate that the bathroom sink empties into the black water tank? If so, since the kitchen sink empties into the galley tank, the shower must be the only water draining into the grey water tank. I am totally confused...
Sobeit is offline   Reply With Quote
Old 07-22-2012, 06:50 AM   #20
Herk7769's Avatar
Originally Posted by Rsgtivr6 View Post
Is'nt the toilet generally mounted right over the black tank so the waste just falls in? I thought that was why the wands work so well. Didn't think they were piped to the tank. Can't see on ours how it gets to the tank, so I am curious now.
In my floorplan the John has 2 45 degrees elbows in the drop into the black tank.
The wand is still long enough to get into the tank, though.
HAM CALLSIGN - KC3FFW
