Old 06-22-2012, 08:24 PM   #1
toilet dumping into grey wate tank
Just purchased new 2010 rockwood mini lite from a bk dealer. After having a different dealer check out the unit, he tells me that the toilet is dumping into the grey water tank and it was plumbed from the factory like that. Also all the wires for the tank monitors were cut under the trailer . this unit is brand new nothing was put together yet with plastic still on the bed . Was it unhappy soon to be laid off workers or bad engineering?
chipshot is offline   Reply With Quote
Old 06-22-2012, 09:10 PM   #2
mike06081969's Avatar
Did they physically verify that or are they just going by the monitors? Mine were reading backward when I got it new. The black monitor registered the grey tank level and vice versa. There were some other issues and they ended up having to replace the monitor panel. Don't let this surprise you. I think quality control issues in the RV industry have become the norm rather than the exception.
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
Old 06-22-2012, 10:41 PM   #3
If the unit is home, open the gray water valve and pipe to to the yard. Then have someone go and flush the toilet and see if water comes out, with the gray valve open. If not, then open the black valve, and see if water comes out. That is the only way to know for sure. I hope the tanks are empty before you perform this test.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-23-2012, 01:32 AM   #4
Rsgtivr6's Avatar
If not, it would make a great "remember when we first got the TT..." story, LOL!
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-23-2012, 03:32 AM   #5
plumbed into grey tank
The rv mech was under the trailer and found the head pipe go directy into the grey tank . The wires were cut to the monitors but 100% verified that the toilet is going to the grey tank. I`m going to check myself to see if my plumber can swap things around
Old 06-23-2012, 05:06 AM   #6
Rsgtivr6's Avatar
Is'nt the toilet generally mounted right over the black tank so the waste just falls in? I thought that was why the wands work so well. Didn't think they were piped to the tank. Can't see on ours how it gets to the tank, so I am curious now.
Old 06-23-2012, 08:42 AM   #7
Iowegian's Avatar
Would improper plumbing (waste going into the gray tank) cause problems with odors in the camper? I am under the impression that only the black water tank has a vent stack. In any case it seems odd that the factory plumbing would have been done this way, as well as the wiring being clipped.
2011 Rockwood Ultralight 2304S
2010 GMC Sierra 1500 CC
Iowegian is offline   Reply With Quote
Old 06-23-2012, 08:57 AM   #8
wolfpack21643's Avatar
My Mini Lite has two vents on the roof and from best I can tell one goes to the black tank and one to the gray tank.
2013 Rockwood Mini Lite 2306 w/Murphy Bed
2004 F-150 4.6 Liter 4x2 Factory Tow Package
2012 - 21 Nights Camped
2013 - 21 Nights Camped
wolfpack21643 is offline   Reply With Quote
Old 06-23-2012, 10:43 AM   #9
VinceU's Avatar
I've owned them with a single stack but vents were Y connected(inside the interior wall ) in route to the roof. Without a vent, the tank would collapse when drained. Odors wouldn't change, but would be nasty if the common practice of forgetting the gray tank level resuls in common shower basin filling, I believe this one has two, there there just not sure how thy are plumbed. NO dwgs from FR.
Old 06-23-2012, 10:58 AM   #10
One way to check this out. The gray tank(s) will have a smaller drain line, The black tank will have a larger 4 inch diameter drain pipe. I really suspect that these people telling you this are looking at the lables on the handles instead of actually verifying the situation. If this is really the case, let the dealer deal with it, since this is a brand new trailer (yea I know 2010) but still brand new and under the 1 year warranty.
