Old 04-16-2019, 02:30 PM   #1
toilet flange question
I am installing 3.5mm (strong 1/8") stone laminate flooring in my TT. I have pulled the toilet - Thetford AquaMagic V foot pedal - but am now wondering - - - should the new flooring go under the toilet flange or can I just butt up to it? If I just butt to it, will the new rubber flange seal be high enough to make up for the extra +1/8" ?
2012 Rockwood MiniLite 2104
gastan is offline   Reply With Quote
Old 04-17-2019, 11:37 AM   #2
Head Rambler
The rubber ring will be more than thick enough to accommodate the extra 3.5mm (1/8"). But you may be able to remove the screws and have enough give in the piping to raise the flange up if you'd like to for peace of mind.
Gotta go campin!
Old 04-18-2019, 07:04 AM   #3
Thanks Bama. I was thinking it would be okay to butt it but started second guessing myself. As far as raising the flange goes - - - it's a glued in flange and I have already pulled/raised it 1/2" for the new plywood (that is fixing the soft floor issues). I don't think there is much more flex left in the tank.
