Old 08-31-2016, 10:06 AM   #1
Toilet is stopped up help
Is there a another valve ?
Sandrar is offline   Reply With Quote
Old 08-31-2016, 10:23 AM   #2
Mr. Dan's Avatar
Can you give us more clues?
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 14; booked = 28
Old 08-31-2016, 10:27 AM   #3
Yes... more clues.
Is the bowl stopped up?
Is the tank full?
Are you trying to drain the black tank?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-31-2016, 10:28 AM   #4
Ashley's Avatar
I'm gonna suggest that to receive some help with your issue that you offer a more descriptive description of your issue, what you may have already done to try and resolve it and what type of unit you have, although I see that is in your profile. You will probably get far better results.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is online now   Reply With Quote
Old 08-31-2016, 10:44 AM   #5
ilmor's Avatar
My initial mental picture was disturbing.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-31-2016, 10:55 AM   #6
Witch Doctor's Avatar
You have a Flagstaff, so as far as I know you have only one. Do you know if it is cable or rod type pull? Did you leave your tank open hook to a sewer hook-up. As you can see we need more info as others have said...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-31-2016, 02:29 PM   #7
toilet clog
Neighbor had the same problem with his Jayco about 2 weeks ago. We let it sit about 4 hours with the black dump valve open. It took the entire time to dissolve (probably to much tissue). But it did drain. Then I had him flush the heck out of it.
You can try turning off the water supply and working a plunger but I don't think that will work. A snale can help break up the clog, but again make sure the water supply is off.
Very little that can go wrong, other than a broken valve and pliers can usually fix it.
Good Luck!
David 01 is offline   Reply With Quote
Old 09-01-2016, 12:30 PM   #8
Schwartzworld is offline   Reply With Quote
Old 09-01-2016, 12:54 PM   #9
jeff
jeff64's Avatar
This is a prime application for a Flush King
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-01-2016, 04:33 PM   #10
Got it taken care, thanks everyone.
