Old 04-04-2015, 02:28 PM   #1
Toilet issues
Started to dewinteriZe my 312qbud and have water spraying out the back of the foot pedal where the water lines connect. From reading online I am thinking the water valve has cracked over the winter. Is there any other part that could be bad
hillyer05 is offline   Reply With Quote
Old 04-04-2015, 05:27 PM   #2
It is a tapered thread. Try silicon tab and a finger tight turn.
CGO - A technical marketing data guru
Almost an owner of a 2014 Hemisphere 312QBUD
2011 Ford F-250 SD 6.7 Diesel
Texas outdoors by way of a PA farmboy.
ChiefGreedyOfficer is offline   Reply With Quote
Old 04-08-2015, 09:40 AM   #3
2013 SunSeeker
We are having toilet issues. No water will come into the toilet when the pedal is pushed down. Any suggestions?
George & Janet White
and 2 4-legged friends
2013 Sun Seeker
GeorgeHW is offline   Reply With Quote
Old 04-08-2015, 09:57 AM   #4
The valve that I am having to replace that goes into the foot pedal. Has a stem that from my understanding pull out when foot pedal is pressed that could be stuck or broke and not allowing water to enter the system.
