Old 11-30-2018, 02:45 PM   #1
tohara's Avatar
toilet leak
Had a toilet water leak on my 2017 avenger ati 27rks, while camping. water coming down the water supply line. called my rv dealer, he said water valve probably leaking. bought $50.00 valve for my thetford aqua magic. installed, still leaking, removed valve while supply like still hooked up, water leaking where supply line was pex clamped to pex fitting. well, supply line was a flexible 1/2" line which is larger than 1/2" pex. no wonder it leaked, wrong type line attached to pex fitting. was able to tighten pex clamp with a set of dikes, to stop leak. supply line is the size designed for a barb fitting. see photo of what I did to fix problem, rv dealer did state that if I did a fix, to add a ball valve in case future leak of the water valve. so I wouldn't have to shut off water to the whole trailer. another design fault by PrimeTime who makes the Avenger line. lines in photo show the cut portion of the supply line and how much it was crimped down to fit the pex fitting
tohara is offline   Reply With Quote
Old 11-30-2018, 05:23 PM   #2
I put a quarter turn shutoff and a faucet supply line to mine
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
leak
