Old 06-24-2018, 02:45 PM   #1
Adony's Avatar
Toilet Shut Off Valve Install
I want to install an emergency water shut off valve to the toilet in my TT.. I went to the HW store to buy a valve that would install / crimp in the braided nylon line connecting to the toilet. They did not carry any valve that would work with hose crimp barbs on each end.. I then asked somebody that repairs RV's about this. He said he would remove the trim board (A) on the floor that covers the PEX/Crimp junction, cut off the PEX to crimp 90 degree fitting and install a Sharkbite valve on the PEX.. I do not even know how much PEX is under the board?? from there he said it should be simple to connect the toilet to the valve using off the shelf toilet hoses.. THIS DOES NOT SEEM SIMPLE TO ME! How would you do it? Pictures show what I am looking at.. Thanks
ID:	177068   Click image for larger version
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 06-24-2018, 03:48 PM   #2
Why not stop at a hardware store getting a barbed quest or pex valve, and crimp rings like they used. That's how I did a manual valve on my city water connection, as a precaution of a bad check valve. Been there for 3 years no issues. If you have the room, you could also get a grey quest 1/2" valve, and screw on at the inlet of the toilet, and screw line onto it. Just a couple of thoughts.
wvram is online now   Reply With Quote
Old 06-24-2018, 04:02 PM   #3
bubbles's Avatar
Just get something similar to these 1/2"
ID:	177077   Click image for larger version
Old 06-24-2018, 04:31 PM   #4
Adony's Avatar
exactly
This is what I was thinking abpout for but have been unable to find..
Ted
2010 T25KS Wildwood
2006 F-250 SD
Old 06-24-2018, 07:33 PM   #5
tom39's Avatar
Amazon under $7 (I guessed at your line size and picked 3/8. Your line could very well be 1/2)
OCSParts MTLB-6 3/8" Brass Barb x Barb Ball Valve, Lead Free, 0.1875" ID https://www.amazon.com/dp/B072MZDND8..._uIcmBb24CFCHP
And here are the clamps. You will however need the tool for the clamps.
Oetiker 16700016 Stepless Ear Clamp, One Ear, Clamp ID Range 13.2 mm (Closed) - 15.7 mm (Open) (Pack of 10) https://www.amazon.com/dp/B00ZJFWAHM..._hLcmBbYCXKKV7
Or they have a no name brand kit that comes with an assortment and the tool.
WGCD 80 PCS Stainless Steel Single Ear Hose Clamps with Ear Clamp Pincer Kit, 7-21mm https://www.amazon.com/dp/B078B9D3M7..._UNcmBbJXTR319
Hope it helps
Tom
2011 Rockwood 8288 SS UL
2012 Chevrolet 2500HD 6.0l
B&W Turnover Ball w/Companion Hitch
tom39 is offline   Reply With Quote
Old 06-25-2018, 03:03 PM   #6
DouglasReid's Avatar
Wont'work on PEX,
The worm gear clamp won't generate enough pressure to seal the connections.
What you want is a Pex 1/2" ball valve, available at any plumbing supply house and a couple of crimps to connect it. Rent the crimper at any rental yard.
https://www.supply.com/shop?nid=7159...SABEgJ3tfD_BwE
Or you could use a "shark Bite" ball valve and no need for crimps or crimper.
https://www.supplyhouse.com/SharkBit...yABEgLWqvD_BwE
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 06-25-2018, 03:17 PM   #7
Adony's Avatar
not using PEX
Thge line that I want to install the valve in is not PEX.. it it plastic/vinyl type tubing..
Ted
2010 T25KS Wildwood
2006 F-250 SD
Old 06-25-2018, 03:28 PM   #8
In that case you can use a 1/2" Pex ball valve and the worm gear clamps.
Old 06-25-2018, 03:44 PM   #9
ben31's Avatar
That would be a perfect setup.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is online now   Reply With Quote
Old 06-25-2018, 03:46 PM   #10
Any plumbing supply house, Lowes, Homedepot too.
valve
