06-29-2017, 06:46 PM
Toilet smell while stored
Hello all, let me start by saying this is my first camper with a toilet so I'm still learning. Here's my problem.
We went camping about a month ago and used the toilet no problem. Dumped the tank before were left for home. Today I was getting the trailer ready for our trip this week and noticed the toilet had an odor. So I stepped on the lever and a nasty odor got me. So am I doing something wrong? Should I be putting water in the black tank when it's parked for a while? Should I put an additive in the black tank? Should I keep some water in the bowl over the seal?
Thanks in advance for the help.
06-29-2017, 06:49 PM
Water or antifreeze over the seal all year helps.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
06-29-2017, 06:50 PM
Senior Veteran RV Owner
A little water and some tank treatment additive if you are storing it for a long time. If I were you, I would fill that black tank up to nearly full, and let it sit for a few hours to loosen up whatever is still stinking the tank up. Then, dump the tank. It should clean it out!
Art Mullis
06-29-2017, 07:09 PM
If you have FHU I would put 10 gallons in it, let it slosh around on your trip and dump when you leave. After I clean our tank I always put water back in the tank so it is not dry, about 5-10 gallons just to slosh and keep everything loosened up.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
06-29-2017, 07:15 PM
Thanks that seems to be the general consensus. So I just put in 5 gallons of water and 2 scoops of happy camper. Ok let it slosh around during my 7 hour drive Saturday.
And I when I get back it will sit for another 3 weeks before my next trip so should I put a little water in the tank and bowl?
Lastly how would I know if the vent is clogged? How do you check that?
06-29-2017, 07:20 PM
7 hour trip will loosen everything.
Yup, just put some water in the tank and I do leave some in the toilet, it'll keep the seal soft and odors down.
If the vent was plugged the toilet would bubble when you go to flush.
06-29-2017, 07:27 PM
Happy camper is a probiotic right? The black tank is a holding tank, not a septic tank unless you carry it with you.
I believe in water & chemicals in my black tank ...3 gallons every time after we dump & then the additive to keep it smelling fresh. Also keep water in the toilet (often with a box of baking soda) to keep the gasket clean / odor free in between outings.
Terri & Joe + Boont & Tasha
Camping a long weekend every month or so since May 2013 in our cute 21FBRS MicroLite to practice for retirement while living here in Florida
Joe is retired.... next camper ordered.... getting ready to change this signature really soon!
06-29-2017, 07:32 PM
I'm not sure, the rv dealer recommended it because it wasn't a harsh chemical and didn't have that chemical toilet smell. Like I said I'm very new to this so I went with what the dealer recommended. And just followed the directions on it
06-29-2017, 07:36 PM
This is from the happy camper website. Is this not a good product? Is there something else I should look into?
"Happy Campers is highly concentrated water-activated mineral blend. It works similarly to bioactive treatments. It is formulated to eliminate odor (not cover it up), break down paper and sewage, and because it withstands extreme hot and cold temperatures, you don't have to add more before dumping."
06-29-2017, 07:46 PM
If your unit has a black tank flush connection used it from time to time when dumping.
I put a liquid enzyme product in mine after I dump and add a few gallons of water then store it like that until the next time I use it. Since I've been doing this the smell has not been present. Actually smells a bit like some sort of soap.
06-29-2017, 07:52 PM
Censored Member
So am I doing something wrong? Should I be putting water in the black tank when it's parked for a while? Yes, you should always have a few gallons of water in the black tank. Should I put an additive in the black tank? I always put a chemical additive in the black tank to control odors. I buy my chemicals from WalMart. Should I keep some water in the bowl over the seal? ABSOLUTELY! If you don't keep that seal wet then over time it will dry out and crack and will no longer hold water. Over the winter pour RV antifreeze in the bowl to keep the seal wet.
Best of luck RVing.
06-29-2017, 07:55 PM
I use Happy Camper and it works great. I can flush my toilet with the ventilation fan running and get no smell coming from the tank. And, yes, you should keep water in the bowl.
Gary
2017 Cedar Creek Silverback 37MBH
2008 Dodge Ram 3500 6.7L, DRW, 4.10 Rear end
06-29-2017, 07:58 PM
Originally Posted by ManlyMan
Best of luck RVing.
Thanks for the clarification. Good to know the right way to store
Ok thanks I'll keep using
06-29-2017, 08:58 PM
I had a similar thing happened to me when I bought a used camper. I did the extreme clean with the happy camper. I dump the whole can in there and filled the tank full. Let it sit in there like that for 2 or 3 days. I never had a problem after that. I only use happy camp, that stuff is great and no smell.
06-29-2017, 09:01 PM
Thanks. It a good to hear people have a positive experience with it. I'll be sure to store my black tank correctly from now on
06-29-2017, 10:30 PM
Just as confused as you
Put 1/4 cup of Dawn dish soap in the black water tank along with your choice of chemical and at least 5 gallons of water. Not only do you need to keep water or RV antifreeze in the bowl to keep the seal moist, but the dump valves need to stay wet too. Dawn dish soap will help keep the holding tanks clean and lube the seals at the dump valves. Do the same with the gray water tank.
Richard & Jill
06-30-2017, 01:02 PM
X2. It acts as a gas trap. Also keeps the flapper seal from drying out.
2016 Salem 27RKSS
06-30-2017, 01:05 PM
Ditto!!!!!
06-30-2017, 01:47 PM
For the last two years I have used a capful of laundry detergent, a capful of Calgon water softener and about 1/4 cup of bleach every time I dump. Supposedly the Calgon makes the sides of the tank slippery so that paper doesn't stick to it so easily. I'm not going to attempt to explain the chemical reactions etc. but I can tell you it works and we full time for at least 5 months of the year. Occasionally I will get a bad reading from the sensors in the tank in which case I drive from one location to another with a half tank or more and let it slosh around. Does the trick every time. We also have a tank rinse built in which I use every time we dump. I also have a Valterra reverse flush unit which I used every couple of months, which goes on where the sewer hose would normally be hooked up and reverse flush all my tanks. I have had virtually no problem with any of my tanks using this system.
Richard Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
