Old 05-12-2013, 01:33 PM   #1
Toilet Splashes When Flushing
Hi All-
I apologize if this is the wrong thread location. Anyway, I recently puchased my first travel trailer and hooked everything up this weekend at my campsite. Everything worked well, but I noticed that whenever I flushed my toilet the water sprayer is so powerfull that water sprays outside the toilet bowl. It is quite a bit of water and I something that I would prefer not to happen. Is there a setting or something that needs to be adjusted to prevent this from happening? Thanks everyone in advance for your help!
Regards,
Brad
BHobbs20 is offline   Reply With Quote
Old 05-12-2013, 01:51 PM   #2
rattleNsmoke's Avatar
I hope you're using a pressure regulator on the end of your fresh water city hose?
rattleNsmoke is online now   Reply With Quote
Old 05-12-2013, 02:09 PM   #3
I noticed same problem , depending on what campground I was in and regulator put a stop to it.
boatnut is offline   Reply With Quote
Old 05-12-2013, 02:12 PM   #4
Not funny having toilet water spitting back at you. The toilet in our old TT used to do this occasionally even with a regulator in place. Our new TT with a different model of Thetford toilet doesn't do this at all and actually has a much better flushing/spraying action.
Having said this, we had one of those basic on-the-hose regulators that failed after less than a year. I only knew because I had installed a permanently mounted gauge on the inside. Bought another regulator and all was good. So you may want to see if your existing regulator is any good (if you have one). I'm thinking of getting one of the hose regulators with built in gauge.
ps: don't forget to put the regulator at the tap end of the hose, not the trailer end so that the hose won't get over-pressurized. And don't forget to take it home. Have seen a few regulators left behind!
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-12-2013, 02:15 PM   #5
Owner/Operator
RodeoGeorge's Avatar
This was discussed in another thread. Don't remember the Thread Title, and have to leave so no time to search. Seems like it was something like Dometic Toilet. Someone that is subscribed to that thread will probably post a link.
There is a solution there involving bending the deflectors down at the nozzle where the water enters the bowl.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 05-12-2013, 02:22 PM   #6
Herk7769's Avatar
When I repaired my Thetford toilet's flush valve I installed a PEX shutoff ball valve in the feed line. You can partially close it to restrict water flow if the regulator is not stopping the splashing.
Name:	Camper Bidet 017.jpg
HAM CALLSIGN - KC3FFW
Old 05-12-2013, 03:26 PM   #7
I do not have a pressure regulator. Sounds like I will need to purchase one. Thanks everyone for helping out! Happy Camping!
Old 05-12-2013, 04:25 PM   #8
Great Horned Owl's Avatar
What happens if you close the seat / lid before you flush?
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 05-12-2013, 05:54 PM   #9
When I close the lid, the water just sprays out from under the lid. I think the pressure regulator might fix the problem. I will keep everyone posted.
Old 05-12-2013, 06:31 PM   #10
The (Bidet) models of water closets usually cost more. Less water pressure is the answer. Youroo!!
