Old 07-27-2013, 06:16 PM   #1
toilet trap door
I have a2012 xlr toy hauler. trap door is not holding water in toilet between flushes.Hold pedal at half to let water in but not flush it can hear water dripping past trap door seal. looks like seal is off centre how is that held in place.Need advice before i try to move it THANKS
wing man is offline   Reply With Quote
Old 07-27-2013, 06:42 PM   #2
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
There might be something in the groove in the seal, the one the blade slides into as it closes. This can cause the blade to not seat properly. Take a piece of bent wire and run it around the grove, with the blade open. Be gentle so as not to tear the seal.
dimurrrw is offline   Reply With Quote
Old 07-27-2013, 06:46 PM   #3
The rubber, if it is like mine is just rolled into a groove that is formed in the toilet, I actually have had the same thing happen, a pair of rubber gloves and someone else holding the pedal down and it will go right back in place with a little hand manipulation. I figured out that the problem I was having was the rubber was dry and hanging on the slider part. I got some rubber safe lubricant like is used in food service, such as when installing o rings in a soft serve ice cream machine and every couple weeks I put a little on my gloved finger and open the flap and run my gloved finger around the rubber where the flapper slides and it has been fine every since, and flushes great,,, Did I say wear GLOVES
thunderalley3 is offline   Reply With Quote
door
