Old 08-21-2016, 07:04 AM   #1
Toilet Valve Leak
Yesterday, when I turned on the water pump the valve on the back of the toilet started spraying water. It ran down into the kitchen before we noticed it. Later I saw that water had dripped out through the plastic attached to the underside of the camper onto the ground. I replaced the valve on the toilet, cleaned up the water that I could see and have been running a dehumidifier to hompefully dry up anything else that might remain. Is there anything else I should do to prevent water damage to my camper?
hellerbrewing is offline   Reply With Quote
Old 08-21-2016, 08:48 AM   #2
Head Rambler
Sounds like you've done everything you should have to mitigate any damages.
Did you drain the underbelly at the low point?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-21-2016, 08:58 AM   #3
SeaDog's Avatar
Your problem is the reason I have started turning the pump/city water off when ever I leave the rig for any length of time. Keep air moving in there.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-21-2016, 09:00 AM   #4
no, do you mean puncture the plastic on the lowest corner?
Old 08-21-2016, 09:10 AM   #5
SeaDog's Avatar
I would go to the lowest spot which on my rig is in the center portion and make a small hole to see if any water comes out.
Retired Navy
Old 08-21-2016, 09:29 AM   #6
It looks like it is just around the bolt where it leaked out. Yesterday I pressed all of the water that I could out of the hole. The rest of the underbelly is still tightly glued to the wood.
It is now a little soft around a small area where it came out. Hopefully there is not too much damage.
Old 08-21-2016, 09:43 AM   #7
Or are you saying I should drill a small hole in the wood?
Old 08-21-2016, 09:46 AM   #8
SeaDog's Avatar
NO I have been assuming you have a travel trailer with the plastic underbelly covering like mine.
Retired Navy
Old 08-21-2016, 09:57 AM   #9
Seems like a piece of particle board with the plastic underbelly glued to it.
Old 08-21-2016, 01:01 PM   #10
SeaDog's Avatar
Take a pic of what you are talking about. If its like mine the wood runs around along the frame and the plastic is attached to that the wood is only about as wide as the frame, once you are away from the frame it is just the plastic material.
Retired Navy
leak
