07-16-2019, 06:25 AM
Toilet won't hold water
Not sure if there is an easy fix.My toilet does not seal now. It will not hold water in the bowl. Is there an easy fix or need a new toilet?
07-16-2019, 07:01 AM
Check to make sure seal is seated properly....(wearing a glove)...step on the foot pedal and let it "Snap" back a couple times to make sure the flapper is closing all the way. Lubrication is also an option. Vaseline has severed me well since 2008. Two TT's that over time would not hold water. Opened the flapper and applied Vaseline all around seal....(While wearing a Glove) and in the spring, the RV anti-freeze that I poured in for winterizing in the fall is still there.
07-16-2019, 07:02 AM
"On the road again"
What brand do you have? I had a Dometic once that ceased to hold water and I replaced a ball seal and that fixed the problem. Here's a link to a video on that subject:
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
07-16-2019, 08:36 AM
I used Dawn and about a gallon of straight hot water in the bowl and let sit overnight. Cleaned the bowl,valve and now it holds water just fine. Seams to happen when it sits for a while with lack of use.
07-16-2019, 08:52 AM
I have a cranky foot pedal. when not pushed just right it actually starts to open seal a little and you cant fill it unless you get it in just the right spot to turn on water but not open valve.
07-16-2019, 08:58 AM
As others have said, the seal will dry out some, especially when sitting and the water evaporates off the top of the seal. When storing for extended periods, I usually add some holding tank deodorizer to each bowl along with a little extra water and have never had a problem with seals.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
07-16-2019, 01:45 PM
I swipe a gallon of my wife's cooking oil once in a while. I use it with little water and have never had a seal problem. It does not evaporate like water.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
07-16-2019, 01:59 PM
Just as confused as you
Hope you don't let her cook with it once your done.
Richard & Jill
07-16-2019, 02:44 PM
We have tried vaseline, silicone plumbers grease, and olive oil, and in comparison this stuff from Tetford works like a charm. http://https://www.thetford.com/prod...d-conditioner/
Bill & Kate, Stone Harbor, NJ
2014 Forest River Wildcat 272RLX Fifth Wheel
2018 Ford F-250 Super Duty XLT 6.2L Gas
Zeke (the Partipoodle) 8 yrs, Ginger (standard poodle) 7 mos - both rescues
07-16-2019, 03:10 PM
I put on my rubber gloves and give it a scrub with a brush around the opening, works every time. Easy and cheap.
07-16-2019, 04:45 PM
We had the same problem and tried all of the suggestions....came to find that we had a hairline crack in the flapper. If you try everything...look closely to see if there's a crack. Under warranty, so we got a new toilet.
2019 Forest River Silverback 33iK
Ford F350 tow vehicle
SW Pennsylvania
Member Travel Resorts of America
Retired and adventurous!
07-16-2019, 11:57 PM
Toilet Seal
I purchase the Thetford toilet seal conditioner and once a month pour it into the bowl to sit overnight. Never had a problem this way...
07-17-2019, 07:57 AM
About once a month I have to turn water off, hold foot on peddle, wipe bottom of seal dry, and smear some plumbers grease under seal. Works every time.
07-17-2019, 02:26 PM
2X on the plumbers grease.
I also make sure there is always water in the bowl.
