Old 05-17-2018, 05:13 PM   #1
Too filter housing
I cannot get the filter canister off. I don't know if I cross threaded it or what. I opened a faucet and am using the tool if can with. Does anyone have any ideas?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2009 GMC Sierra 1500 Crew Cab
kevin79 is online now   Reply With Quote
Old 05-17-2018, 05:44 PM   #2
Mine was a booger to get off also. I just kept working it till it came loose.
whitewinghunter is online now   Reply With Quote
Old 05-17-2018, 05:50 PM   #3
Scoundrel
HangDiver's Avatar
After they've been seated in place for a while they can be difficult. Mine is the same way. Keep at it.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 05-17-2018, 05:54 PM   #4
Once you get it off, lube it with Danco silicone paste on the O ring and it's mating surface on the canister.
Old 05-17-2018, 06:07 PM   #5
klickitatjim's Avatar
Usually have super course threads. I highly doubt it's cross threaded, it would break before they got it seated.
klickitatjim is offline   Reply With Quote
Old 05-17-2018, 06:41 PM   #6
Ok, dumb question, I turn it counter clockwise, correct?
Old 05-17-2018, 06:49 PM   #7
fonzie's Avatar
Looking at it, turn left with wrench (looking from top, clockwise)
Fonzie
Old 05-17-2018, 06:57 PM   #8
Try putting your hand under it and lifting up as you turn. You don't say what model you have, but some of them have teeth at the top to prevent them from unscrewing.
2011 Traverse LT, 3.6L, FWD
Old 05-17-2018, 07:07 PM   #9
It is the FR1 that uses the KW1 filter.
Old 05-17-2018, 07:11 PM   #10
Mine was really tight too. A strap wrench may be needed. Be sure to turn the right direction. Viewing from the top you turn clockwise.
My17Ram is offline   Reply With Quote
