Old 06-25-2012, 08:38 PM   #1
MilCop4523's Avatar
Too much vibration noise when water pump running
Any one getting a loud vibration noise when the water pump is running?
With my pump for the water tank running I am getting major vibration noise from the Water hoses against the shelving and wall
I need to isolate the hoses with something.
Any one had a similar problem they've fixed
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 06-25-2012, 08:56 PM   #2
mike06081969's Avatar
I'm on my third RV and every one of mine have done the same thing, so I assume that it's normal.
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
Old 06-26-2012, 01:34 PM   #3
J. Parham
snjparham's Avatar
I installed a noise isolation kit which is flex line connected to pump between hard plastic lines. I also added an accumulator tank. These two things combined made my pump barely audible.
2011 8528BHSS
2013 Silverado 2500HD 6.6L
Nights Camped in 2011: 32
Nights Camped in 2012: 85
snjparham is offline   Reply With Quote
Old 06-26-2012, 01:40 PM   #4
MilCop4523's Avatar
Any pictures?
I might be able to modify what you did
Old 06-26-2012, 02:08 PM   #5
Wanna Be Camper
SaskCampers's Avatar
Go old school and put a computer mouse pad under the pump then rebolt the pump to the floor or what ever it was attached to. Usually works great and is about as cheap a fix as you will find.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 06-26-2012, 02:09 PM   #6
MilCop4523's Avatar
currenlty on a rubber mounted base. Its the water hoses hammering it out to a different beat under the sink assembly and wall
Old 06-27-2012, 08:04 AM   #7
Herk7769's Avatar
One solution:
Name:	Pump Storage Diagram.JPG
HAM CALLSIGN - KC3FFW
Old 06-27-2012, 08:19 AM   #8
MilCop4523's Avatar
I'll post what a snake pit ours is tonight.
Part of the problem is they seemed to shove about an extra 5 inches on each hose. The lines are so long that they are up tight against the cupboard bottom and the walls.
I am thinking some rubber mounted clamps to secure them to the plywood backing I put in for my RVQ support under the sink and a few hose washers to fit under the clamps attach points.
Herk I see a spare parts kit?
Any thing of interest in there we could all use?
I have the hose and coupler for the winterizing.
Old 06-27-2012, 08:38 AM   #9
Herk7769's Avatar
Sorry,
Contrary to popular belief, I am not the only one who brings spare "show stopper" parts along.
The photo was posted by a member. I used it as a guide when I re-did my water compartment.
The biggest noise reduction is isolating the pump from the plumbing. Most of my noise was from the pipes vibrating against the cabinet. A thick rubber pad (several mouse pads thick); looped vinyl hose on the input and output; and an accuumulator (to run less often) quieted mine right down.
Old 07-25-2012, 01:00 PM   #10
Buckymaster's Avatar
Everyone of my rigs, from several manufactures, had this issue. I purchased split foam pipe insulation from the Big Box stores. Split for easy on, and it has a peel and stick tape to close it up. I was able to access the tubing from several locations and covered it up with the insulation. Comes in several sizes. Keeps it from pounding the walls and cabinets.
CURRENT - - 2017 Shasta Phoenix 33ck
OLD - - 2007 Forest River Wildwood 312BHBS LA
OLDER -- 1997 Sunline Solaris T-2970 Advancer pkg
Still Running - - 2008 F350 CC Lariat 4x4 6.4 Diesel
Buckymaster is offline   Reply With Quote
led pad
