Old 07-07-2014, 10:47 AM   #1
Torn out tank wiring
My dog got under the camper and tore apart my wiring for the two waste storage tanks. I still have wires connected to the tanks, but I don't know how to connect them together. It is a 2001 Salem Forest River. The monitor inside only seems to have four wires (blue, red, green and brown) I think, going into it for these tanks. Does anyone have a wire diagram or a picture to help me rewire this back correctly? The wires from the tanks all seem to be 18 or 20 gauge, but I think they are going to wire into a thicker wire.
labguru is offline   Reply With Quote
Old 07-07-2014, 10:59 AM   #2
Dave_Monica's Avatar
I found this pdf that has the info you need...
Dave
Old 07-07-2014, 11:27 AM   #3
So, it looks like all 3 levels in the tank get tied together, then all the whites together. Not sure these colors match mine, but it helps. My monitor is similar to the one on page 163, but not the same. Thanks for the help!
Old 07-08-2014, 02:43 PM   #4
Herk7769's Avatar
So on the tank:
White - Ground (tie to ground from other tank and run to display.
Yellow - 1/3 light - to red resistor pack
Green - 2/3 light - to red resistor pack
Red - Full - to red resistor pack
Brown Resistor pack single wire to display - Black Tank.
Gray Resistor Pack single wire to display - Gray tank.
Name:	Horst Probe Install 008.jpg
ID:	57627   Click image for larger version
Name:	Horst Probe Install 007.jpg
ID:	57630   Click image for larger version
Name:	Horst Probe Install 009.jpg
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 27 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 31 views)
HAM CALLSIGN - KC3FFW
tank, wiring
