Old 05-31-2019, 01:02 PM   #11
Prime Member
If sized properly, your tow vehicle should be able to handle the weight easily. In my experience, it's actually easier to tow with a full FW tank. It adds tongue weight make the trailer more stable.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 05-31-2019, 01:46 PM   #12
Originally Posted by B and B View Post
So no propane on or water when travelling. Next they will say don't put clothes on the closet rod as it might fold under the sheer weight of a couple t shirts..
I do both! Full water and used to run propane fridge on when travelling.
Yep, a full water tank is about the same as two extra passengers. No one seems concerned then. I suppose they tow with an empty fuel tank too... wouldn't want to carry that extra weight you know.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 05-31-2019, 02:04 PM   #13
Crookedread
crookedread's Avatar
I always travel with full water tanks. I can avoid drinking really bad water if I want to and it is awesome to have when traveling in windy conditions. That extra 480 pounds down low changes the center of gravity making it much more stable. I know it saved my bacon once in South Dakota and once in Nevada!!
crookedread is offline   Reply With Quote
Old 05-31-2019, 02:13 PM   #14
Its a reoccuring issue. Not the weight for me; not the MPG... but just more the tanks and supports are known to be weak link. Potential to damage/drop the tank due to hyro surges from sloshing while driving ...... we avoid filling tanks on the road whenever possible. Boondock a lot but all of our regular GO TO spots have a common area water source. We normally drive empty and fill up when we arrive.
Just a choice we all have to make but no doubt there are 1000's of stories about damage tanks from hauling water (weak tanks).
gbaldwin is online now   Reply With Quote
Old 05-31-2019, 02:20 PM   #15
bikendan's Avatar
Frontal air resistance affects mpg WAY more than extra water weight.
We almost always travel with full tank, since we dry camp a lot.
Equalizer WDH
Old 05-31-2019, 02:29 PM   #16
rlh1957's Avatar
If you don't mind burning extra fuel carrying the extra weight, and the water weight doesn't put you over your weight or balance envelope then I would invest in having the brackets, beams, straps or whatever beefed up or a design add on. Whoever designed and engineered these straps went to the LAR school of engineering for structural support... LAR being Looks About Right! I haven't seen a rig yet that a full tank traveling didn't bow out, stress out the support brackets and straps. Saw a 42 foot fifth wheel drop a FW tank and drag it because one of the three straps was still partially holding it. The assembly line fix is easy for manf if they'd change. But they insist on repairing it with what they put on in the first place. So fix it yourself.
If I confirm I can source reliable water closer to my jump off point I wait till there to top off the FW tank instead of pulling a full tank of water that I won't need for 300, 500 or so miles. To me warranty work and fixes aren't much good if it's the same materials used as went bad the first time. I do my own work and get someone who's had actual experience with my model to keep me up to speed.
rlh1957 is offline   Reply With Quote
Old 05-31-2019, 02:37 PM   #17
Getting water near your stopping point is ok IF everything goes right.
I've been saved twice by carrying a full tank.
Once when we got to a park, the water system was down and wasn't repaired until the third day there. It was nice to have water.
Second time we were traveling with my Uncle and about 300 miles into a 400 mile day when he had transmission problems. We wound up having him towed and we spent the night in a repair facility parking lot. I had water, he didn't. We were able to pump 15 gallons into his rig for them to use and we still had plenty.
Do what you want. I'm carrying water.
Old 05-31-2019, 02:40 PM   #18
adarklake's Avatar
On the other side there's me apparently. I've towed a Micro Lite with an overflowing full tank for many miles down an extremely rough dirt road without being very gentle. No issues. 2018 19FD it was.
2019 Wildwood 171RBXL
2015 Jeep Grand Cherokee Overland 4x4 5.7L V8 HEMI
adarklake is offline   Reply With Quote
Old 05-31-2019, 02:45 PM   #19
rlh1957's Avatar
5Picker makes a great point from actual experiences.
Old 05-31-2019, 02:57 PM   #20
YEP! Just do what works for ya.
tank, travel, water, water tank
