Old 08-19-2013, 12:50 PM   #1
97Powerstroke's Avatar
Two grey water tanks and one drain valve?
Kinda new to RV'ing... I bought a 2007 Rockwood Signature Ultralite 8244S fifth wheel. On the tank level annunciator panel, it has a "galley" tank and a "grey"tank level. I only have one grey water drain valve on the outside. So I'm guessing both drain into a common drain and there is a check valve somewhere keeping the shower from back flowing in the kitchen sink?
97Powerstroke is offline   Reply With Quote
Old 08-19-2013, 01:01 PM   #2
Dave_Monica's Avatar
Unless the previous owner piped the 2 gray tanks together, you may have only one gray tanks. The factory set-up Rockwood would be a sewer connection for the gray/black tanks and a separate sewer connection for the galley tank. It's not unusual to use the same tank monitoring set-up whether all the tanks are there or not.
Does the galley tank ever register any level when you're using the kitchen sink and does it return to 0 after the gray tank is dumped?
Dave
Old 08-19-2013, 01:02 PM   #3
Brother Les's Avatar
You may need to look a little more for the other valve. Mine has the black and one grey that is close to the tires. The other grey pull handle is two feet from the back bumper.
Brother Les
Old 08-19-2013, 01:05 PM   #4
TURBS's Avatar
Even if they both did drain into a common tank the shower drainage would not back up into kitchen sink unless the tank was full.
My guess is you have two waste tanks "black" and "grey"
If you only have one sewer outlet and two pull handles its assured.
Otherwise you'd have two sewer outlets and three pull handles.
Turbs
Old 08-19-2013, 03:07 PM   #5
Yes, I have one sewer outlet with two pull handles.
Old 08-19-2013, 03:13 PM   #6
Then I would say that you only have 2 waste tanks...1 gray, 1 black. Even the current production 8244WS show only one gray tank.
Dave
Old 08-19-2013, 03:40 PM   #7
That makes sense! Thanks for the replies.
Old 08-20-2013, 07:56 PM   #8
My Flagstaff has two grey tanks and one handle. They appear to simply be plumbed together and keep even levels.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-20-2013, 09:07 PM   #9
My '09 Rockwood 2701SS has 2 gray tanks and 1 Black tank with 2 dump valves, one for gray and one for black. The two gray tanks cross feed and I love the setup.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
Old 08-20-2013, 09:13 PM   #10
I guess I could still a hose in the kitchen sink. If the "grey" tank starts to fill up and not the "galley", then it means I only have one tank.
