Old 02-19-2013, 03:00 PM   #11
TexasAggie-99's Avatar
Thanks for all the responses! I'll have to dig around and see if I can find an access panel to check the valves. I assume it's somewhere on the inside of the RV since there isn't access to them from the outside panel.
TexasAggie-99 is offline   Reply With Quote
Old 02-19-2013, 04:07 PM   #12
Did you turn on the water heater switch, Mine was on the same control panel with the water pump,Mine did the same thing until i turned on the switch ...it lites the heater in the auto mode...? IF it works like mine
Geaux is offline   Reply With Quote
