Old 08-25-2013, 10:16 PM   #1
Typical RV Bath tub design?
Just wondering if the tubs typically in RVs are built similar to those in houses, with a lip the extends up from the top edge, so that the tub surround comes over top of it? Mine is not siliconed and not sure if I need to - no silicone would lead it to breath and keep moisture out (I think) if there is a lip.. If there is no lip, no silicone would be a sure way (I think) to water leaking in behind and rotting the walls...
glen1971 is offline   Reply With Quote
Old 08-25-2013, 11:58 PM   #2
Fulltime family RVer
From the little that I know, they're the same and many manufacturers recommend against caulking it for the reason that you mentioned.
ependydad is online now   Reply With Quote
Old 08-26-2013, 08:46 AM   #3
X2. During our PDI I asked the service tech about caulking the bottom and he advised against it.
