Old 04-08-2016, 04:30 PM   #11
lesptr's Avatar
I'll fill it to the top and try again.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 04-08-2016, 04:45 PM   #12
lesptr's Avatar
Still won't prime.
2015 F350 6.7
Old 04-08-2016, 04:53 PM   #13
B and B's Avatar
I have also had issues. Not conceptual but overfilling the water tank fixed my problem every time, crack open the pump inlet connection so it leaks to let the air out and the water gets in and primes the pump.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-08-2016, 05:08 PM   #14
Flybob's Avatar
One problem with blowing out lines vs adding pink stuff, is you can not blow out the water pump itself. Unless you ran it for a few seconds after you blew out lines, it may have had water in it and froze. My pump runs for a good 3-4 mins before the lines pressurize.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-08-2016, 05:23 PM   #15
Who Dares, Wins
doc73's Avatar
Never thought of that.. I've wrecked a few pump heads from letting it freeze.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-09-2016, 06:36 AM   #16
lesptr's Avatar
I keep it heated during the winter so freezing shouldn't be a problem. I'll see if I can't contort my arm enough to loosen the inlet side to let out air.
2015 F350 6.7
Old 04-09-2016, 06:37 AM   #17
lesptr's Avatar
The tank was filled until it overflowed, still won't work.
2015 F350 6.7
Old 04-09-2016, 06:46 AM   #18
bubbles's Avatar
Have you checked the filter between the pump and fresh water tank?
Old 04-09-2016, 06:46 AM   #19
lesptr's Avatar
Tank is, full so it's not that.
I haven't found an air leak, but can't rule it out.
No way I know of to check the others possible causes with the tools I have on hand. I'll pull the plug tonight and let the 49 gal tank drain. It'll be raining anyway.
2015 F350 6.7
Old 04-09-2016, 06:47 AM   #20
lesptr's Avatar
Unable to get water pump to prime.
Any suggestions on make and model pump with which replace this one?
2015 F350 6.7
pump, water, water pump
