Old 04-09-2016, 04:28 PM   #41
B and B's Avatar
The pump should be under warranty, a easy replacable item .
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-09-2016, 04:53 PM   #42
Georgia Frog Rally 2018
aceinspp's Avatar
Depends when he bought. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 04-09-2016, 06:41 PM   #43
lesptr's Avatar
It's no longer under warranty.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 04-09-2016, 06:42 PM   #44
lesptr's Avatar
And you haven't seen where it's located.
2015 F350 6.7
Old 04-10-2016, 09:49 AM   #45
I'm having the same issues. 2016 nitro xlr, I have had it a year and got it to prime 1 time. I just put a new pump on because I thought that was it. But nope it won't prime.
Arkguy29 is offline   Reply With Quote
Old 04-10-2016, 09:58 AM   #46
aceinspp's Avatar
Must be sucking air some where then. Se any water at all in the pump? Later RJD
Days camped 2017 62
Days camped 2018 18
Old 04-10-2016, 10:14 AM   #47
Witch Doctor's Avatar
All the pumps are self priming, you can also run out of water and the pump will stay on but you will not damage it. You either have an air leak somewhere or your pump head is stuck or ripped. try to remove your screen filter that was shown above fill that container turn on the pump see if it draws water out of it, you have a leak somewhere between your FW tank and pump. Mine has a valve in between make sure that is open. You have to close mine to winterize. Just a thought all units are plumbed differently. IMO that is what it sounds like, Also last trip out had a similar problem I unscrewed the strainer at the pump and reinstalled it the pump started to work again, Fluke thing I guess. You also should have a Sur-Flo pump.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 04-10-2016, 10:38 AM   #48
Who Dares, Wins
doc73's Avatar
The heads can be replaced but I would also second taking it apart first. Like I posted before, mine was a grain of sand in the pump. This is what cause mine to keep running and not pump water since it also could not prime.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-10-2016, 03:16 PM   #49
Unfortunately no one has mentioned this, if I missed it I'm sorry, when you winterize, if you don't run the pump after you open the low point drains, but before you blow out the lines, to make sure all the water is out of the pump lines and pump body. Water can remain there and can damage the diagram or pump plastic housing. Because there is a check valve before the pump the air used to blow out the lines does not go back thru the pump.
We had this happen on our service trailer, to one of our 7 gpm shur flow pumps a few years ago.
You can order a new front part of the pump, but it is much easier to just replace the entire unit.
Rich5117 is offline   Reply With Quote
Old 04-10-2016, 03:35 PM   #50
I filled the holding tank up today while having pump on and hot water vented. It primed. I have a large hot water heater. I let the air out of sinks and now leaving pump on to see if it is going to loose prime.
pump, water, water pump
