Old 08-28-2014, 11:42 AM   #41
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Zoeneens, I am starting to realize what your problem might be. You said you did a lot of research before buying your home which is a Park Model trailer, that it has a generously sized black tank and the gage on the monitor panel shows 1/4 full (those gages are not very accurate btw.), plus you used the toilet for only a few days.
As far as I know gray and black water tanks are an option for most Park Model trailers and in your case the black water tank might not be directly under the toilet.
So, when you first tried to clear the blockade you probably hit an obstacle a short distance below your toilet, that's where an elbow was installed and from there the pipe continuous to your black water tank. If that's the case you could try an ordinary toilet plunger to clear the pipe or if this doesn't work you need to get a sewer snake or someone who can do it for you. If that's the case the plunger would be my first tool of choice and then the sewer snake or toilet auger (Walmart, Home Depot, etc.) and once it starts to open up water is your best friend.
This is still guesswork, but a strong possibility.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 08-28-2014, 12:12 PM   #42
RSchleder's Avatar
Had a similar problem on one of our Rv's. The "down tube" that connects the toilet bowl to the black water tank extends into the black water tank several inches. The blockage occurs when you put several flushes of "solids" into the black water tank with little or no water in the black tank. It is exasperated by using too little of water during the flush to essentially "float/wash" the solids away from the "down tube". The solids mound and coupled with the toilet paper, clog the down pipe where it is close to the bottom of the tank and the water in the pipe backs up into the bowl.
Here's how you deal with it.
1) turn off the water to the toilet.
2) get a stout, long (3'-4') rod/snake
3) breakup the mass that's clogging the down pipe (up/down and side to side motion).
4) take a garden hose WITH a spray nozzle, point it directly down the down tube ( be sure to wrap an old towel/cloth around the hose when it enters the bottom of the toilet as it was splash or perhaps want to back up a bit before it breaks loose.
5) Once the clog is broke loose, fill the black tank with the hose/spray nozzle until it reads about 2/3rd or 3/4 qtr's.
6) Let it soak a few hours and then dump by pulling the outside valve.
7) be sure to put 2-3 gal of fresh water in your toilet each time you dump to clean the system and then close the outside valve, add 3-4 gal of water to your black tank. Now it's ready to use as the solids will float away from the down tube. Don't skimp on the flushing process either!
Best of luck. Feel free to send my a private message if you need any assistance.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 08-28-2014, 12:20 PM   #43
Zoeneens's Avatar
Used wrong TP....toilet blocked.
Great!! This sounds promising! Now, shutting off the water to the toilet. That would be to shut off the pump to the entire unit? With the initial paper clog I was able to reach down pretty far and the pipe bends to the left. I WILL do this rv life successfully...even if it kills me!
Zoeneens is offline   Reply With Quote
Old 08-28-2014, 12:22 PM   #44
ARLO
Can you see down the hole with a flashlight? Any logs floating?
rlocicero is offline   Reply With Quote
Old 08-28-2014, 12:25 PM   #45
Zoeneens's Avatar
Bits of broken down toilet paper comes up....just a little. This has a swirl water action. Can't see too far in.
Old 08-28-2014, 12:39 PM   #46
heavynlori's Avatar
Originally Posted by f1100turbo View Post
Never really seen a permanent spot without full hookups.
That's weird.
TURBS
"SABRE OWNERS UNITED"
Our seasonal site is water and electric only - honey wagon weekly as you need you pay and they pump greys and black - usually when you are not there so tank flush not an option but we do backwash ours when we arrive so it helps cleans sensors and add some water at the same time
Have not had any issues in the 12 summers there....
heavynlori is offline   Reply With Quote
Old 08-28-2014, 12:50 PM   #47
RSchleder's Avatar
Yes, you can turn off the water to the entire RV or if there is a valve behind the toilet, you can just shut it off. Probably, if the pipe bends a bit, a tape/ sewer tape should be used to break up the clog!
30 years RV'ing
11 different RV's
Old 08-28-2014, 12:52 PM   #48
B47
Originally Posted by Cypressloser View Post
Valterra Products, Inc. A01-0183VP Rinse A Tank Wand: Amazon.ca: Automotive
You can also find it at RV dealerships and maybe even Walmart.
Also if the tank is not completely full, you could try and dump a couple bags of ice in the toilet and water and then take the trailer for a spin. The ice in combination with water can work wonders on caked on stuff.
$112.00 plus shipping for a simple wand you can make yourself?
Old 08-28-2014, 12:54 PM   #49
RSchleder's Avatar
You can buy a "sewer tape/snake" at most hardware stored. They come in different sizes, get a small one. Explain what you want to do, they will help you select the correct size.
30 years RV'ing
11 different RV's
Old 08-28-2014, 01:04 PM   #50
$112.00 ???
Ordered: 2021....
Old 08-28-2014, 01:08 PM   #51
vinmaker's Avatar
I would think all you would need is a plumbing snake to clear the lines.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 08-28-2014, 01:14 PM   #52
B47
$112.00 ???
I checked the site 3 times and each time it showed $111.99 plus shipping. I just checked the site again and it was $CND 9 or 19 - forgot which.
Got to be a typo.
Old 08-28-2014, 04:54 PM   #53
Zoeneens's Avatar
Got the sewer tape at Walmart. Turned off the water pump. Snaked the toilet and it works!!! Flushed a lot of water. Learned a lot today. Thank you so much for all of your help. YAY!
Old 08-28-2014, 05:02 PM   #54
NELA
Weezer's Avatar
WOOHOOO! Did you get some Angel Soft TP while there at WalMart? Much cheaper than the stuff that sold as RV approved.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-28-2014, 05:07 PM   #55
B47
Glad to hear it - hope all future things "move along" better.
Old 08-28-2014, 06:10 PM   #56
RSchleder's Avatar
Glad to hear all is well. Keep up the good work. You're doing GREAT!!!!!!
30 years RV'ing
11 different RV's
Old 08-28-2014, 08:36 PM   #57
Got to be a typo.
Sorry, couldn't reply sooner but sometimes life gets in the way.
Interesting, so the link displays a different price based on location, that is creepy.
Ordered: 2021....
Old 08-28-2014, 08:41 PM   #58
B47
Just checked the Amazon link - $CND 19.99 now.
I never saw two different locations either.
Old 08-28-2014, 08:43 PM   #59
I am sooo happy for you.
One final question, does this mean together we can move mountains?
Ordered: 2021....
Old 08-28-2014, 08:49 PM   #60
cjearle
cjearle2's Avatar
We try not to put TP in our system. Have a small waste basket with trash bag in it for TP. One it prevents filling up the tank to soon and less problems.
Aviator Wright Flyer 1912
F-250 2014
cjearle2 is offline   Reply With Quote
