Old 02-02-2014, 09:24 AM   #1
Wayne & Kim
Wayne & Kimmy's Avatar
Using outside shower blue hose for black tank flush
I'm looking for some thoughts and advice for using the outside shower blue hose for black tank flush. I have a separate hose that I have used for the flush, and it has worked well for me. But I saw a camper recently that had the blue hose hooked up the the flush. From a convenience standpoint, it seems like a great idea as he can just turn the water on without dragging out another hose, and could even introduce some hot water to the mix. I understand that there may be a drop-off in water pressure compared to being hooked directly to the faucet. My understanding is that the flush has a built-in back flow preventer which in theory should prevent potential contamination of the blue hose.
I welcome any thoughts from the forum!
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
Wayne & Kimmy is offline   Reply With Quote
Old 02-02-2014, 12:55 PM   #2
Helmsey's Avatar
Hmm, I haven't thought about doing that but sounds like a great idea. I'm curious to see other folks thoughts on this and if anyone around here has done it.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 02-02-2014, 01:32 PM   #3
I have done it that way using the hot water, however without actually seeing inside the tank after flushing it's hard to tell how effective it really is! It did seem to bring out more crud with hot than with cold water.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 02-02-2014, 01:59 PM   #4
Old Bones's Avatar
This is good to know. We are applying for a seasonal site this year and if we get it, one of my concerns was how I was going to flush the black tank. Usually the water spigots are too far away from the site to drag a hose to.
2013 Forest River Surveyor SP296
Old Bones is offline   Reply With Quote
Old 02-03-2014, 09:20 PM   #5
Happy Keystone Owner
dbarr's Avatar
When you dump your tanks at the dump station and you see the hose hanging from the pole...do you use it to fill your fresh water tank? Same thing.
Keep your fresh water and sewer water separated.
Yeah, I know there's a backflow valve on the flush but what happens when it fails?
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
dbarr is offline   Reply With Quote
Old 02-03-2014, 09:46 PM   #6
sherdep's Avatar
keep in mind this if it is a full hookups site
I always use a separate hose for the black tank flush which happens to be black so I know which is fresh and which is flush
I have a T type fitting on the end of my outside filter housing with back flow preventers on both sides. The campground also has a back flow preventer on there side as well.
after using the tank cleaner I turn the hose off with the valve on the y pipe to minimize any contamination and once I remove the black tank flush hose I run the water on the y pipe to flush it just in case and I never have the camper city water connected while doing this either.
I keep spare back flow preventers in my pack of stuff and wear blue latex disposable gloves when I dump or handle any thing that has to do with waste tanks.
if it is a site I have to dump at a dump station - its the same thing with the black hose for tank flush
sherdep is offline   Reply With Quote
Old 02-04-2014, 12:25 AM   #7
Kaadk's Avatar
Wife bought one of those x-hose things for the trailer. Since it's not rated for drinking water (like the white hoses) I use it for the black flush. Goes in the same storage compartment as the Rhino, which is in a completely different area than the white hoses.
I don't know how some people can put their sewer hose in the bumper, and then throw their elbows and things in the same storage as their fresh lines.
Kaadk is offline   Reply With Quote
black, black tank, black tank flush, show, shower, tank
