Old 07-29-2016, 08:41 AM   #1
firsthere's Avatar
Using Showerhead Shutoff Valve
When dry camping, to save water we adjust the water temperature at the valves then shut off the shower head valve, get in, lather, rinse, repeat... each time the valve is reopened the water is really Hot. I heard opening the bypass valves a little bit at the water heater might help this. Anyone else have a suggestion? (5 gal suburban WH)
TT- 2016 Grey Wolf 21RB
TV- 2004 GMC3500 4x
Nights camped 2016- 20
Days at dealer 2016- 37
firsthere is offline   Reply With Quote
Old 07-29-2016, 08:47 AM   #2
Mine is just the opposite. Water comes out cold for a second. I just turn the head away before I turn the valve back on. Hits the wall, not me.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is online now   Reply With Quote
Old 07-29-2016, 08:55 AM   #3
Does your water fully shut of when you shut off the valve? It's supposed to trickle (leak) when shut off so avoid the hot water issue. What's happening is the hot water "pushes" the cold so when you turn it back on, the hot is taking up both lines for a bit so there's no cold to push out ... does that make sense?
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 07-29-2016, 08:58 AM   #4
TURBS's Avatar
Mine trickles, However when you turn it back on I get cold water first.
I do not have the normal stock shower head and have a normal household unit with no shut off.
I installed a shut off after the water mixing handles before the hose.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
Old 07-29-2016, 08:59 AM   #5
Mine seems to shut off completely. Came with the trailer.
My previous trailer I put an Oxygenics on it and added the shutoff valve to that. It came out hot when I opened it.
I would prefer to be frozen than scalded.
Dwayne and Susan
Old 07-29-2016, 09:02 AM   #6
Mr. Dan's Avatar
Cold here, too. I turn the head away, too.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 14; booked = 28
Old 07-29-2016, 09:07 AM   #7
Oaklevel's Avatar
Ours comes out hot for a second or two. Just learned to point it away for a second or two. never worried too much about it.
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 07-29-2016, 09:19 AM   #8
firsthere's Avatar
Ours trickles when off also and we did learn to aim it away when turning back on. Sometimes I forget though and Woooo.. look out. Maybe a different shower head or inline gate valve would slow the delivery.
Our dealer left the bypasses at the water heater partially open and when I asked why he said for scalding?
TV- 2004 GMC3500 4x
Old 07-29-2016, 12:32 PM   #9
dmchapman's Avatar
I have found that even with the trickle valve the water temperature does not stay constant. I suspect whether you get hot or cold when turning the shower head back on would depend on how far the hot and cold faucets are opened. The one open more might allow more flow, thus feeding back into the opposite supply line. Just guessing.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
Old 07-29-2016, 12:35 PM   #10
Yikes. I just ordered the Oxygenic head. You saying there is no shut off on the handle. I thought that thing was promoted to save water.
I have been frustrated trying to control the scald freeze issue with the stock head
Tom48 is offline   Reply With Quote
show, shower
