01-28-2018, 11:28 AM
PlanoPaul
Using vinegar mixture to flush Suburban water heater
I am considering using a 50/50 mix of vinegar/water to flush my Suburban water heater due to all the calcium buildup. Question to members: Do you have any tips or warnings about removing the Pressure release valve in order to add the vinegar/water mix to the water heater? That seems to me to be the easiest way to get it into the water heater by pouring it in through a funnel. Reinstall the valve. Turn the heater on for 4 hours then drain and flush with clean water.
2017 Flagstaff 30WRLIKS
01-28-2018, 11:55 AM
You should be fine without turning on the WH.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-28-2018, 12:34 PM
Grammar Pedant
I'll state the obvious. If you use a vinegar solution to clean and then later use a bleach solution to sanitize, make sure that they don't mix. Flush the lines good before you go between vinegar and bleach.
Former RV: 2018 Rockwood Mini Lite 2504S
01-28-2018, 12:58 PM
Saw this show up somewhere... Gives a few ideas on how to get the vinegar in.
http://www.loveyourrv.com/cleaning-r...-tank-vinegar/
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
01-28-2018, 01:12 PM
Not sure I'd take the valve out.
I'd make some sort of hose adapter to screw into the relief valve opening (there are threads) to hook a hose and funnel onto and pour it in without removing the valve. Even though the hose would be connecting to the bottom of the valve, by holding the funnel/hose higher, it would fill the tank. Open a hot water spigot to allow air to escape.
01-28-2018, 01:15 PM
Isn’t the purpose of the anode rod to stop the build up of scale? I
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
01-28-2018, 01:23 PM
Nope, it sacrifices itself through electrolysis from corroding/rusting the steel tank.
01-28-2018, 01:33 PM
AKA: 'tiredTeacher
No. The anode rod prevents the walls of the heater and the heating element from being eaten away by electrolysis.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
01-28-2018, 01:56 PM
Be sure to leave the relief valve open if the calcium build up is severe the reaction creates carbon dioxide gas. This can build excess pressure in the system.
01-28-2018, 02:00 PM
The anode is completely unrelated to scale. Scale is the buildup that occurs from the minerals that are in the water. The acidity in the vinegar dissolves the scale. It can be quite significant depending on the water.
The anode is a sacrificial metal that gets attacked first by the electrolysis which can get generated in your system, from different possible sources but most typically by the presence of dissimilar metals. Without the anode, the electrolysis corrodes the steel liner of your water heater. Both the one in your RV and the one in your home should get replaced every 7-10 years.
Charlie
[SIGPIC]
2005 Coachmen Sportscoach Encore 380DS
2019 Jeep Wrangler Rubicon Unlimited
01-28-2018, 02:03 PM
What if you drained the WH , then put your mix thru the winterizeing setting, then open a hot water apickot then let it sit , drain and flush the system , then see if it was worth it ?
01-28-2018, 02:14 PM
I don’t turn the water heater on during soaking, just let it soak overnight.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
01-28-2018, 02:41 PM
Just speculating, but wouldn't CLR do the trick? It is designed with washing machines, dishwashers, etc in mind. Not sure why it wouldn't work in a water heater.
01-28-2018, 06:03 PM
Overnight with no heat, turn up the heat and the job is done in an hour...
Couple of gallons of white vinegar is cheaper - and absolutely safe!
Al
01-28-2018, 06:26 PM
NEVER !! that's a caustic chemical and you don't want any chance of residue making it through any of the water lines. Vinegar is completely safe and easy to flush out.
01-28-2018, 06:29 PM
I've seen the video that describes pretty much what you want to do. The end results were very impressive with the amount of scale it removed from the tank and heating elements.
01-28-2018, 06:42 PM
Lets go camping!
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
01-28-2018, 07:03 PM
NH Maple Maker
Turn on the water heater after you put in the vinegar/water mix. That's what I do to clean the pans on my maple syrup evaporator. Heat makes it work faster and do a better job. I've tried it both ways. When I use it cold I have to let the evaporator sit for 2 weeks to get it clean and then it's not as clean as bringing it up to a boil and then letting it sit overnight.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
01-28-2018, 07:10 PM
I replace my mag rod every year to be safe. Was susprised how fast they eat up. You can also get a HW adpeter that fits on end of garden hose to flush HW tank.
01-31-2018, 05:10 PM
I removed the pressure relief valve and added 2 gallons of horticultural vinegar 30% and filled. Left overnight, it did pretty well. Heating may do a better job. Used a lighted scope to view before and after . Not sure that I would remove the PR valve a second time
WyomingJack
2015 CC Silverback 29 RE
2014 GMC 2500 HD
