If you have the outside anti-freeze hookup, check that the valve between it and the pump is closed, and the valve between the fresh water tank and the pump is open. Some RVs have a single 3-way valve; if you have that, it should be aligned to the FW tank, not the anti-freeze hookup.
2011 Traverse LT, 3.6L, FWD
