Old 08-11-2013, 06:51 PM   #1
Valve between hot and cold lines
I have a 2009 t29bhbs and the valve between the hot and cold lines has a leak. What is the purpose of this valve? Can I remove it or does it need to be replaced? With the valve open the hot and cold mix leaving luke warm water. When closed the valve leaks more.
Thanks in advance
Brad
Bmccolm is offline   Reply With Quote
Old 08-11-2013, 07:09 PM   #2
leaker
can you post a picture of the valve? Some valves have poppets and a nut with packing which just needs to be tightened. usually under handle
Vacationman is offline   Reply With Quote
Old 08-11-2013, 07:13 PM   #3
Here is the photo
Old 08-11-2013, 07:47 PM   #4
That is the bypass valve for winterizing your system around the water heater. It should not be removed (and you'll be learning how to use it).
