Old 04-20-2008, 07:44 PM   #1
Very little water
I have a 2005 Cardinal. The water flow is so restrictived that the shower will not stay on. The parks are not high volume water parks but we camp with 4 other couples and everyone has enough water to take a shower but us. Is this a Cardinal problem or just a problem with our camper. We had a Terry before this camper and went to the same parks and had enough water volume/pressure to shower.
bcford250 is offline   Reply With Quote
Old 04-20-2008, 08:19 PM   #2
There a few variables to chack, check water flow from supply, check hose for kinks, check water ragulator for debris, make sure all valves are open, check shower head for debris.
Old 04-20-2008, 09:21 PM   #3
MRimmer's Avatar
Remove the water saver from the shower head. My flagstaff was the same way and we now enjoy nice showers.
Pressure was good but that restriction made it a slow dribble.
Mike
MRimmer is offline   Reply With Quote
Old 04-20-2008, 10:40 PM   #4
welshman599's Avatar
Send a message via MSN to welshman599
You say its a 2005, but I take it you just got it. I also take it the water pressure is low throughout the trailer - kitchen taps, etc, and not just the shower. If so, I'm wondering if perhaps the original owner installed a water filter cartridge that is restricting the flow badly. You might remove the filter and see if it makes a difference.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 04-21-2008, 05:14 AM   #5
KyDan's Avatar
If you have a regulator on your garden hose, remove it and
try that.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-21-2008, 01:55 PM   #6
You might also check your water filter. I have a Cardinal 5th wheel and it came with a built in (cartridge) water filter in the basement.
Honest John is offline   Reply With Quote
Old 04-21-2008, 02:49 PM   #7
Rockinwood's Avatar
I dont have the same model, but had the same problem, my water filter was clogged, I ended up taking out and used w/o the filter
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 04-21-2008, 05:52 PM   #8
powerboatr's Avatar
Mike
ditto
AND... our water heater had a restrictor on the hot side outlet
and then i removed all of em from every faucet
dont forget the pressure regulator , the cheap one pice brass ones will clogg up and not flow, or if the input side is to high they will practically shut down.
the built in water filter will get you to
get a good watts regulator or similiar
they still are a bit low on flow volume but much better than the standard option
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 04-21-2008, 06:16 PM   #9
We have had it for about a year. Have been so busy with other things that we haven''t had time to do a really good check to find the problem. Last year it was just slow. We took it to a blue grass festival last weekend and had almost no water. I think the filter is probably the problem. Thanks for the help. It is parked at another blue grass park now. That festival is in two weeks. Whe I get back to the trailer, I will try the things listed here until I find the problem.
Old 04-21-2008, 08:48 PM   #10
I'd check the water filter first BC. It's the easiest to troubleshoot... simply unscrew the cannister, remove the filter and reinstall the cannister. If water pressure improves, it is the culpret. Have fun at the festival!
