Old 02-16-2015, 08:57 PM   #1
Vibe 6504 rides low
6504 is low to the ground. When I try to use a portable waste container, the tap in is so low I literally have to continually lift the hose to get it to drain. And when using a sewage hook up at a camp site, I can have a problem with the hose being high enough at the tap in to drain correctly.
I have purchased two leveling blocks that I will use to raise up the camper when I park. That should put it up a few inches, and should help. But other ideas? Anyone see this is the vibes? I look at other campers and they seem to ride much higher.
Ideas welcome.
jsk125 is offline   Reply With Quote
vibe
