Old 03-31-2019, 06:57 AM   #1
Viking 17BH Freshwater Tank Issue
Good Morning,
I own a 2018 Viking 17bh. I haven't used my freshwater tank until this year. I noticed when filling that there is an uncapped line directly behind the low point drain for hot and cold water. This line is attached to the bottom of the freshwater tank to a "T" fitting on the direct bottom of the tank. When I am filling the freshwater tank this immediately starts leaking, not a lot but a steady trickle.
I haven't used the tank so I dont remember if there was a cap on there originally. In addition, I do not know how to drain this tank.
HappiCamper is offline   Reply With Quote
Old 03-31-2019, 07:07 AM   #2
cavie's Avatar
Originally Posted by HappiCamper View Post
Good Morning,
There are two drains down there. One is the tank drain attached to the bottom of the tank. It will have a valve on it. The other is a an vent/overflow line with no valve.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 03-31-2019, 07:17 AM   #3
Thats just the thing, it is just a "T" fitting. I can find no valve to turn to drain the tank. I see the low point drain but that just drains the camper water lines. As soon as I put water into the tank, the line attached to the "T" fitting starts trickling water from it.
Old 03-31-2019, 07:25 AM   #4
I have attached a picture of my setup on the tank for reference.
Old 03-31-2019, 03:36 PM   #5
bedubya's Avatar
Great photo, but exactly where is it leaking?
'17 Toyota Tacoma 4x4
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 03-31-2019, 03:45 PM   #6
It looks like the end cap is missing from that line from the T, that looks like the tank drain.
2018 Flagstaff 26RBWS
Equalizer 1,200/12K WDH
2018 GMC 2500HD Crew cab 6.0L
deereman1026 is offline   Reply With Quote
Old 03-31-2019, 03:50 PM   #7
Out the forward tube, the one without the cap. Drained a 1/3 tank overnight
Old 03-31-2019, 03:56 PM   #8
cavie's Avatar
It appears someone combined the vent and the drain. Tthat will not work. No way to stop tank drain without a cap. If you cap then there is no tank vent/overflow
Old 03-31-2019, 04:11 PM   #9
Fluffywhitedogs's Avatar
Did you buy the trailer new? Even though my Clipper 17bh is a couple years older, I would expect it to look the same but it sure doesnít...
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
Old 03-31-2019, 04:27 PM   #10
The two drains in the foreground are the hot and cold low point drains. The line on the T fitting is the tank drain and it appears to be missing the cap. You need a cap on it.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
tank, water, water tank
