Old 06-28-2016, 08:36 AM   #1
BandJCarm's Avatar
Viper, Dominator, or what?
My "rhino" hose I was forced to 'purchase' when picking up the new TT has developed pin hole leaks after two uses. So it ain't much "Rhino".....
Need one with permanent fittings, and easy to snap together, and easy to put 90 degree clear end on (I have that already).
What is the difference in Valterra Dominator or Viper? Why are there two? Is one sturdier? Thicker? What?
Thanks.......
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-28-2016, 05:12 PM   #2
BandJCarm's Avatar
No opinions?
FROG AR-0019-242
Old 06-28-2016, 05:20 PM   #3
2SGMRET's Avatar
I also had the Rhino and replaced it with the Viper. I believe the Viper is more puncture resistant than the dominator. Much happier now that I tossed the Rhino
2SGMRET is offline   Reply With Quote
Old 06-28-2016, 05:21 PM   #4
raspivey's Avatar
I wonder if you didn't just get a bad one. I don't have the Rhino, but I've had one of those Camco Revolution hose sets from wally world that's held up very well for two years now. Tight enough that when I collapse them and put the caps on they hold vacuum for months.
Old 06-28-2016, 05:28 PM   #5
BandJCarm's Avatar
Thanks. IF I get the 20' Viper (two ten foot sections) and a 15' Viper.....will they come with ends already permanently attached, and will they clamp together easily????
FROG AR-0019-242
Old 06-28-2016, 05:28 PM   #6
BandJCarm's Avatar
Some love them, so I do suppose I got a bad one.
But.........I have a bad one.......it has holes.
FROG AR-0019-242
Old 06-29-2016, 10:20 PM   #7
Retusps's Avatar
Hey Band, I went with the Viper 20' (2x10'ers). Felt way more flexible and durable. I use them with a "Y" connection as I have two gray tanks. So far I have not needed a third section. No they don't have end caps, but I did purchase enough to seal all ends when not in use. Also, I use a clear connector to aid in total dumping. Hope this helps
No matter where you go, there you are!
2018 3500 Chevy Silverado, Duramax, CC, Z71, SRW
2014 Palomino Solaire Eclipse 297rlds
Husky Centerline w/d hitch
Retusps is offline   Reply With Quote
