Old 03-03-2015, 07:03 PM   #1
Voltage on Tank Sensors
Does anyone know what voltage should be on the tank sensors when the tank is full and empty?
oakprk is offline   Reply With Quote
Old 03-03-2015, 07:12 PM   #2
Wa11y757's Avatar
I think 12 volts dc because it works if you are not plugged in to "shore" power. But...it's only "hot" on one of them. The others are the other side of the circut. The " stuff" inside completes the circuit.
Wa11y757 is offline   Reply With Quote
Old 03-03-2015, 07:26 PM   #3
Flybob's Avatar
Not sure you will have much luck checking voltage, the sensors are usually connected to op amps that simply look for low current ( completed circuit) between the level sensors.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-03-2015, 07:56 PM   #4
Herk7769's Avatar
Here is what I have on the sensor array. You would need to do the math to calculate a voltage from your actual battery voltage and the drop across the individual resistor pack.
A Full indication is zero ohms (short circuit) so zero volts read.
An Empty indication is resistance above 188K Ohms, so voltage read would depend on input voltage.
ANY probe shorted to ground (the white wired probe) by slime, hair, or crud touching the tank walls will read a full tank.
See my review on Horst Probes here Horst tank Probe Installation
And a film of why you need to upgrade your probes here:
Name:	Horst Probe Install 008.jpg
ID:	70654   Click image for larger version
Name:	Horst Probe Install 009.jpg
ID:	70655   Click image for larger version
ID:	70657   Click image for larger version
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 34 views)
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 28 views)
HAM CALLSIGN - KC3FFW
tank, voltage
