Old 11-13-2011, 11:16 AM   #1
jit
w.h. bypass valve
a new owner here..winterizing for the first time. can someone tell me where the water heater by pass valve is located. I have located the pump and the heater box, but the actual lines to the heater are not readily visible to me.
jit is offline   Reply With Quote
Old 11-13-2011, 11:37 AM   #2
Rebel702's Avatar
You need to post your specific unit info to get better guidance.
Rebel702 is offline   Reply With Quote
Old 11-13-2011, 11:56 AM   #3
jit
sorry about that...its a 2012 puma 25 footer. pump and heater is under the kitchen sink area.
Old 11-13-2011, 12:15 PM   #4
I dont know which model Puma you have , But I have a 2012 Puma 25RS.
The water heater is on the outside of the trailer with the tank right behind it. To get to the bypass valves you need to remove the cover from the inside panel. Mine on the 25RS is under the fridge. Then you just turn the inlet valve and the outlet valve off and the heater is bypassed
Taz 23 is offline   Reply With Quote
Old 11-13-2011, 12:27 PM   #5
Rebel702's Avatar
If you look in the WH compartment and see which direction the water lines come from, then go inside and look for a panel that you would remove to get to the by-pass.
Model #???
Old 11-13-2011, 03:14 PM   #6
bikendan's Avatar
it would help knowing the specific model, since they can be in different areas for different models.
that way owners of the same model, can be a better source of info.
Old 11-13-2011, 05:53 PM   #7
jit
thanks to all for the info...found all I was looking for in the trailer..
