Want to flush black tank, but slide out covers door to bathroom
I'm sure this has been talked about before, but I was not able to find it via search.
I just bought a 2011 Wildwood 26TBSS. I've had it out twice, once with full hookups, once with water/electricity only. At the full hook up site, I was able to drain the black tank while hooked up to city water and flush more water thru via the toilet. Then after draining the black and gray tanks, I capped everything up, dropped some treatment in the toilet and added 2-3 gallons of water. While maybe not perfect, my black tank was rinsed some and should not be too bad.
Our last trip, all I had was partial hookups and at the end of the weekend I had to use the dump station. Of course, I'm all hooked up and my slideout is in, which covers access to the bathroom. I cannot flush the toilet and I can't even run a hose to the toilet. An as far as I can tell, there is no blank tank flush connection on the outside of the camper.
It does not help that there is no electric or water where I store the camper, so now it's sitting in storage, with no water or tank treatment in the black tank.
If you have this situation with your trailer, I could really use some tips on how to maintain a somewhat clean black tank.
Thanks in advance!
