Old 09-18-2018, 08:05 PM   #1
Newbie RVer
Wanted - replacement low point drain
While familiaring ourselves with our first RV, a 1993 Class B Coachmen, spotted this broken low point valve. What is the best way to repair it and might as well upgrade the unbroken one as well.
Thank you in advance from this complete novice.
Adriana is offline   Reply With Quote
Old 09-19-2018, 10:24 AM   #2
SharkBite fittings work on PEX and are EASY to use.
TranceX2 is offline   Reply With Quote
Old 09-19-2018, 10:29 AM   #3
The Grey lines are not Pex. they are Polybutylene.
The inside diameter of the Polybutylene (grey) is slightly different in size from the Pex. Go to the Pex section in Home Depot and look for a "transition" fitting that allows you to crimp the fitting to the "grey" Poly and on the other end run the new Pex. The transition fitting conforms to the two different inside diameters.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 09-19-2018, 02:59 PM   #4
Oops, I should have caught that too.
Old 09-19-2018, 08:50 PM   #5
Newbie RVer
Is there any reason why I could not simply replace the valves in polybutylene? Does Home Depot carry grey pipe and fittings? Put a ball valve either inside or below, depending on room.
Old 09-20-2018, 03:36 PM   #6
Send a message via MSN to Tiggerdad
How To Video: Transitioning Pipe Materials using Fittings | SharkBite
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 09-20-2018, 07:56 PM   #7
Newbie RVer
You guys have saved me a huge amount of trial and error! Thanks!
drain, replacement
