Old 01-16-2020, 09:43 AM   #1
Warm not hot water
2019 Forest River Sunseeker
L.P. Gas Water tank Atwood MPD 93755
Shower, warm water NOT hot, quickly cold
Is this model adjustable? If so how?
Confused is offline   Reply With Quote
Old 01-16-2020, 09:47 AM   #2
cavie's Avatar
no adjustment. Do you have an outside shower? Turn off both valves. Not just the shower head.
Be sure your WH by-pass valves are in the proper position.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-16-2020, 09:49 AM   #3
Mr. Dan's Avatar
X2 - This WH bypass valve setting is the most common cause of the issue mentioned. Either one of these conditions will cause the system to mix hot and cold water.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 01-16-2020, 11:06 AM   #4
wmtire's Avatar
See if this thread can help:
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 01-16-2020, 11:51 AM   #5
I’m making the assumption that your water heater model is the same as in our 2020 Sunseeker. If so, then no, the water heater thermostat is not adjustable. However, there is an adjustable thermostat available for this water heater, which I have installed.
https://www.amazon.com/Atwood-93105-.../dp/B001BZ36HM
Water being too cold as in your case may be due to a defective thermostat. My experience with these heaters is that the water is typically scalding hot. I installed the adjustable thermostat to reduce the temperature to a safer level.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 01-16-2020, 03:33 PM   #6
Cold shower
You have the valves turned on wrong on the hot water heater has nothing to do with the thermostat.
johnlochbuie is offline   Reply With Quote
hot water, water
