2008 George Town 378...in stalling washer/dryer can not locate drain outlet. Hot and cold water easily available.
common sense tells me it would be in the wall behind the washer. But we all know about common sense when I comes to building an RV. look for some screws to remove a panel.
If however you are looking for the down pipe for the washing machine hose it should be right there with the water connect feeds in the washer closet. It may be a black pipe with a cap on it. If you have washer water hose connections then your unit is washing machine prepped and I think all GT 378's were then the down pipe should be there.
I am aware of that...my question is where do I pick up the drain location in the cupboard designated for the washer in the motor home. I expect it is in the wall (and I must cut a whole in the wall to get to it) just where is the exact location?
See post 4. My 2012 GT 378 has the same location for the washer as your 2008. My coach came with washer prep installed and the drain pipe is right there with the washer faucets. It's not behind any wall or panel. It is black and has a cap on it. It extends quite high into the cabinet.
Replied to bubbles by email. Not sure if reply will show up on this board
Are you sure you replied by email? That's not the normal method here. Usually, replies are by Private Message (PM and Bubbles received none) or by simply posting in the Quick Reply box at the end of the thread.
This is my GT378 that has the washer prep. Looks as though the tap is spliced into the vent tube. You evidently don't have a washer prep or this would be obvious. I might mention that one individual that has the prep had to pull the water heater to connect the water feeds to the prep faucets. I don't know of another way to acquire a drain.
Wish mine was that easy....has to be in the false wall left side between rest room and this cabinet.
Thanks for all your heip...You have gone way out of your way to heip.
