Old 08-29-2016, 07:58 AM   #11
We use the Geo Method as well and don't add any extra water to the black tank after dumping. I do this because one of my RV's in the past has had a paltry 23 (or was it 28?) gallon black tank and if I added ~5 gallons I'd have lost almost 20% of my holding capacity before I even started camping.
One of the main reasons we bought a RV in the 1st place was to have our own bathroom so we use the tanks to the max almost every time we go camping. I don't put much thought into the "dummy" light gauges. I turn off the pump, push down on the toilet foot pedal and see how my space is there ... just don't do this right before dinner
my two cents ...
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 08-29-2016, 08:17 AM   #12
Herk7769's Avatar
Adding a few gallons to start is just good insurance to prevent the dreaded "Tower of Doom" under your drop tube into the tank.
A dry tank will allow that first flush to stick to the bottom starting the tower.
Subsequent uses will keep the tower going and at dump time, the push from the water might not completely clean the floor allowing it to dry out and build a solid base for future troubles.
Ounce (or gallon) of prevention...
HAM CALLSIGN - KC3FFW
Old 08-29-2016, 01:50 PM   #13
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Terier View Post
I don't think it would hurt to refill the tanks but it's added weight (not a problem for most people) but then you have full tanks to deal with at the start of your trip.
He leaves his RV at the campground. I'm guessing he is seasonal.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 08-29-2016, 01:55 PM   #14
moff34's Avatar
Grey & Black tank cleaning
To aid in keeping our tanks clean, I installed a sewer drain connection next to my storage pad at home. It has been a great investment. A clear sewer connection elbow is also a critical part of the process as I know how many refill / flushes of the black tank it takes before the water runs clear.
When camping, prior to what I know will be our final dump before leaving, I add Calgon water softener. On moving day, I dump the black tank, refill / flush five times, then dump the grey tank. I then fill both tanks to 1/3 full and add Calgon water softener and three Tide laundry pods to each tank for the drive home.
During the drive home both tanks get a thorough cleaning from the agitated water, water softener, and laundry detergent mix.
Upon arrival at home I immediately hook up to my sewer connection and drain the black tank. I am always amazed at how much more crud flows out even though I flushed the tank 5 times immediately before leaving the campground. I turn on the tank flushing hose and continue refilling and dumping until the water runs clear, usually about 3 more times. I then dump the grey tank and run water in the sinks refilling and dumping until the water runs clear. I leave the drain hose attached for an hour or more with both dump valves open to make sure they are thoroughly drained then close everything up until the next trip.
After 25 years of motor homes and trailers this method, continually modified over the years, has served us well.
moff34 is offline   Reply With Quote
Old 08-29-2016, 02:35 PM   #15
TandSH's Avatar
Originally Posted by NMWildcat View Post
We always dump, rinse, then add a few gallons with chemicals to the black tank. Also dump a little of the yellow gray tank deodorizer in all the drains.
X2
2017.5 Cedar Creek 34RL2
2016 Flagstaff 8528IKWS Diamond Pkg (For Sale)
2016 F-250 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 08-29-2016, 02:48 PM   #16
RollingDownTheHighway's Avatar
If we're going out again soon, I'll dump 5 gallons or so and some cleaner in the black tank. I let it sit and swoosh around to and from the CG's, then dump it at the CG.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 08-29-2016, 02:57 PM   #17
ilmor's Avatar
Originally Posted by Larry Tiner View Post
I couldn't find a link addressing this. When we leave the RV at the campground and head home, we dump all tanks and flush black tank. I'm hearing a strain of thought that recommends dumping, cleaning, then filling with clean water and letting it sit until we return so the 'stuff' in the tanks don't dry out.
Any thoughts?
Black tank should never be empty. Even after draining, you should be adding the chemical and a gallon or so of water (whatever the chemical instructions state). Even during the winter I have RV antifreeze in there.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-30-2016, 01:32 AM   #18
Thank y'all for the input. Took notes.
Larry Tiner is offline   Reply With Quote
Old 08-30-2016, 09:14 AM   #19
Wolverine 1945's Avatar
Seams like most missed that ???
Wolverine 1945 is offline   Reply With Quote
Old 08-30-2016, 12:26 PM   #20
Waste Tanks ---full or empty?
How much Calgon water softener do you add? Liquid? What size are your tanks? I keep mine pretty clean but the sensors are off so must be some crud on them. I do have the clear connectors for the drain hose and luckily have a built in tank flush system which I use.
wildwoodtraveler is offline   Reply With Quote
tank
