Old 08-28-2016, 12:48 PM   #1
Waste tanks --- full or empty?
I couldn't find a link addressing this. When we leave the RV at the campground and head home, we dump all tanks and flush black tank. I'm hearing a strain of thought that recommends dumping, cleaning, then filling with clean water and letting it sit until we return so the 'stuff' in the tanks don't dry out.
Any thoughts?
Larry Tiner is offline   Reply With Quote
Old 08-28-2016, 01:23 PM   #2
Mr. Dan's Avatar
I never refill my tanks with clean water or anything else after I dump when leaving a campground. I DO add 5 gallons or so of water to my black tank.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 42; booked = 20
Old 08-28-2016, 02:01 PM   #3
Thanks, Mr. Dan. I never thought about leaving it empty would dry out the residuals. 5 gallons sounds good to me.
Old 08-28-2016, 02:38 PM   #4
Terier's Avatar
I also do the same as Mr. Dan.
I don't think it would hurt to refill the tanks but it's added weight (not a problem for most people) but then you have full tanks to deal with at the start of your trip.
Old 08-28-2016, 04:05 PM   #5
NMWildcat's Avatar
We always dump, rinse, then add a few gallons with chemicals to the black tank. Also dump a little of the yellow gray tank deodorizer in all the drains.
Scott and Liz - Southern NM
Old 08-28-2016, 04:35 PM   #6
Great tips! Thanks!!
Old 08-28-2016, 04:52 PM   #7
SkipBest's Avatar
Tanks
We dump rinse and dump.
When the tank is drained we add a few gallons and some Tank Tech RX. All seems good using this method.
SkipBest is offline   Reply With Quote
Old 08-29-2016, 07:01 AM   #8
Herk7769's Avatar
I always leave a few gallons of water in the black and gray tanks during the season with 1 laundry load of detergent and 1 laundry load of Calgon water Softener.
When I winterize, I add 1/2 quart of RV-Digest-It (by Unique) to each tank and fill them to the top and let them sit for 72 hours or more; then dump and turbo rinse (I installed one on my gray tank, too).
My tanks are link new, don't smell, and (with Horst probes) the tank monitoring systems work flawlessly.
HAM CALLSIGN - KC3FFW
Old 08-29-2016, 07:06 AM   #9
Flybob's Avatar
X2 on dump completely when leaving. Once home I add 3-4gals of water and a an oz of Rid-x to help decompose anything that may be left. When I winterize in the fall, I add 10 gal of water and some Odoban and let sit for a few days before I drain and winterize.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-29-2016, 07:06 AM   #10
Dave Lyon's Avatar
After dumping at the campground, I dump 5 gallons of water into the black tank with laundry soap and let it slosh around on the trip home. I then drain it and fill it with water and drain it again; and store it with both gray and black tanks empty.
I use the geo method and never had issues with tank smell or dried waste in the black tank.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
tank
