Old 04-24-2018, 07:40 PM   #1
pokey's Avatar
Waste tanks pull handles
Hello all, I may be in the wrong forum but it's active so thought I would post here. I recently purchased a 2006 Forest River Cardinal LE29 Fifth wheel. Everything is set up on a permanent lot and going fine. Question, In my marked waste water compartment (a cap screws off for access) there are 2 t-handles side by side. I would think 1 is for black, the other for grey but no markings to know??? Anyone have this type of set-up or possibly a Forest River that does also? Thanks!
Pokey
Permanent RV'er
2006 Cardinal 29LE
Why do today what you can put off until tomorrow.
Retirement life........
pokey is offline   Reply With Quote
Old 04-24-2018, 07:51 PM   #2
Oaklevel's Avatar
Sometimes the black tank handle is black and the grey is grey in color but not sure in your case.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 04-24-2018, 07:55 PM   #3
pokey's Avatar
Both are black, a head scratcher.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 04-24-2018, 08:00 PM   #4
Hook them up, dump both handles, then fill up the gray through a sink or shower. Pull both again...question answered. There may not exist an easier method.
Then place labels!
BrettN is offline   Reply With Quote
Old 04-24-2018, 09:00 PM   #5
pokey's Avatar
Then place labels!
Much easier if I can ever get a Forest River customer service rep to answer the phone and ask.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 04-24-2018, 09:10 PM   #6
bikendan's Avatar
Pokey, not sure if you'll get someone to answer on a 13 year old RV.
Equalizer WDH
Old 04-24-2018, 09:20 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Easy, when you pull a handle and it comes out brown it is...... black
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 04-24-2018, 09:42 PM   #8
TKN 516's Avatar
This isnít something you need a rep for. Just hook up to the sewer and pull the handle, wait for the tank to drain, then close it. Do the same for the other handle. Easy peasy...
Let us know if you have other questions.
Also, you can ask almost anyone at a park where you are hooked up and they should be able to show you.
Tim & Nicole
2018 Legacy 38C
2015 Jeep Rubicon TOAD
TKN 516 is offline   Reply With Quote
Old 04-24-2018, 10:04 PM   #9
planopat's Avatar
On my Berk the black is for black and grey is for grey but your unit is 18 years old and there is no way to tell what has been changed or replaced and a rep would probably say the same. Take the advise of all who have responded above and pull one and after it drains, pull the other. There are several hose components available that are clear or semi-clear if you are hesitant about being able to see exactly what's draining. Good luck!
planopat is offline   Reply With Quote
Old 04-25-2018, 01:12 PM   #10
Why not get a clear plastic L=-fitting and attach that to the exit fitting. Attach your hose and use both tanks as you would normally. It will be readily obvious, which is which... not to be gross. If you can see the pipes that come from the tanks to the exit valves, the grey pipe may be significantly thinner than the black pipe.
mandb is offline   Reply With Quote
tank
