Old 07-25-2013, 11:54 AM   #1
Waste Valve Cable Problem
There are long cables from T handle to the valves which operate the various valves. The black valve was not working and I determined that the problem was that the cable was so tight that the friction between the wire and the inner portion of the rubber caused the rubber portion to come out from the housing which supports the tee handle. I'm not sure how to refasten this into the handle housing - any suggestions..
texasdude is offline   Reply With Quote
