Where and what is leaking?
Is it leaking passed the valve and down into the pipe (all internal to the pipe), maybe the valve is not shutting all the way (blockage) inside the pipe or is it leaking to the outside (like dripping onto the ground from the valve/pipe)?
Is it the valve itself, like a seal, dripping between the mating surfaces of the valve? Or is it from a crack in the pipe?
If it is just a seal inside the valve that is not hard at all, most valves have four bolts, unscrew them and separate the valve in half and pop a new seal in.
If the valve itself is cracked (plastic housing) that is not too bad either, just some standard pipe work, gluing and fitting a valve in.
If it is a cracked pipe, not too bad either, just some pipe work, or a patch kit depending on type of plastic piping you have.
When the valves are exposed the more room the better but do-able either way.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
