Old 05-29-2013, 09:25 AM   #11
Send a message via MSN to Tiggerdad
Originally Posted by OldCoot View Post
What are you suggesting they put lock tight on if not the handle?
The valve gate has a short stub with male threads and can not be held to tighten the rod because it is recessed. That stub spins in the gate. Take the end on the rod, put a little locktite on it and screw it on that stub. Put a little locktite on the other end of the rod and screw the knob on. See Rockwood's picture to see how the gate is hidden.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 05-29-2013, 10:07 AM   #12
Phat Phrog Stunt Crew
elind's Avatar
You could put a nut on the stub, pull it out, and then snap on a pair of vice grips on the shaft to keep it from turning. You could also use the nut as a locking nut behind the knob.
2014 Wildcat 327ck
elind is offline   Reply With Quote
