Old 05-27-2013, 07:30 PM   #1
waste water tank valve rod
we are newbies- we bent the rod by pushing too hard- has anyone experienced this problem? And how did you solve it?
thanks in advanced for all your replies. We will post our outcome when we get there.
K hood
khood is offline   Reply With Quote
Old 05-27-2013, 07:43 PM   #2
Send a message via MSN to Tiggerdad
Call Prime Time and they will send you new ones. Put a little lock tight on the threads to keep them from coming off while you travel.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 05-27-2013, 08:07 PM   #3
bikendan's Avatar
how did you know they have a Prime Time trailer? it's not in their profile and it's their first post.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-27-2013, 08:32 PM   #4
They didn't loose the handle, they bent the rod which might be able to be straightened unless it was bent real badly.
Old 05-28-2013, 07:39 PM   #5
It would probably best to replace the whole valve, as the rods are hard to straighten out. They do not seem to work all that good after you try and starighten them.
kdcamper
2013 Rockwood 8329SS
2011 Chev. 3500 CC 6.0l
kdcamper is offline   Reply With Quote
Old 05-28-2013, 07:41 PM   #6
Perhaps I made the wrong assumption. How do you know that they don't?
OP, call the manufacturer. They will probably send you a free one.
Old 05-28-2013, 07:46 PM   #7
I didn't say they lost the handle. I lost a handle and the rod that it was attached to while traveling. Seems that the pin that is part of the slide gate rotates in the body of the valve. This prevents the rod from being able to be tightened if the valve is enclosed under the belly. Loss of rod and handle is not uncommon on the Prime Time that I have. Factory sent me 2 new rods, a new handle and small tube of Lock Tite within a few days of calling them and at no charge.
Old 05-28-2013, 08:37 PM   #8
Phat Phrog Stunt Crew
elind's Avatar
My handles broke off after a couple of uses. The threaded ends of the valves are outside of the frame. At first I got threaded rod, a coupler, and some knobs to make a stronger handle/rod assembly. That could work, but instead I just screwed the knob onto the valve end threads. That worked fine, just a little further reach to the knob. If the handle goes thru the frame then make the handle with the threaded rod and coupler.
ps My TT is a Primetime/LaCrosse
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-28-2013, 08:44 PM   #9
This is what happen to mine, as i pulled the handle the double nut broke the plastic cover.....this was a normal pull and the handle was not stuck.
Old 05-28-2013, 08:50 PM   #10
I didn't say they lost the handle...
"Call Prime Time and they will send you new ones. Put a little lock tight on the threads to keep them from coming off while you travel."
What are you suggesting they put lock tight on if not the handle?
