03-27-2017, 07:53 PM
Water back up in tub - tanks empty
I have a 2016 Coachmen Freedom Express and it is new ( only used 2 times last fall). I unwinterized this past weekend and the antifreeze is backing up in the tub. I let it sit (level) until today and still same antifreeze in tub. Tried using plunger to no avail. Any ideas????
03-27-2017, 08:12 PM
Hook up drain hose, place in 5 gal. bucket and open gray tank valve for a little. ????
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
03-27-2017, 08:16 PM
Drain hose on tank dump or like a siphon hose?
03-27-2017, 08:18 PM
Who Dares, Wins
Drain the tank into the bucket to MAKE SURE it is empty. Do you have more than one tank for gray, a galley tank? Not sure what the Freedon Expres has.
2015 Chevy HD D-Max
2022 Impression 315MB
03-27-2017, 08:22 PM
Just a gray tank and black tank. I opened gray tank and ran sinks for 30 minutes to flush antifreeze. No problems then I noticed probably half a gallon of pink in the tub and closed the tub drain. When I open it nothing happens. No water comes out of gray tank drain.
03-27-2017, 08:28 PM
Just for giggles, open the black tank drain and see if it has water in it.
I have seen instances were things got plumbed to the wrong tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Who Dares, Wins
So when you say the AF is sitting in the tub, nothing is draining or am I misreading? Not sure how it could get a clog over the winter if it ran fine before the winter. Do you get resistance in it when plunging? Can you get a fish or something in it GENTLY to make sure you do not feel and obstruction or get to the trap under the tub?
2015 Chevy HD D-Max
03-27-2017, 08:29 PM
Who Dares, Wins
I have seen instances were things go plumbed to the wrong tank.
Good point
2015 Chevy HD D-Max
03-27-2017, 08:30 PM
I thought of that. Black tank also empty.
03-27-2017, 08:32 PM
We bought in right before cold weather. The shower was used 3 times. Winterized and now the AF just sits there. It back up into the tub from runners my the sinks. I am no plumber but new plumbing plus it worked fine last winter.
03-27-2017, 08:47 PM
dead mouse or critter over winter in tub drain? Mouse building nest hauling in debris? Hard to believe a little would not flow?
03-27-2017, 08:49 PM
Hadn't thought of that. How would you suggest checking that ?
03-27-2017, 08:50 PM
Not a drop will drain. Even tried with a plunger. Zip
03-27-2017, 08:51 PM
Who Dares, Wins
Fish in the pipe, or inspection camera. I have an acess panel next to my tub I can remove to get tot he tub trap. Remove it and look into the trap?
2015 Chevy HD D-Max
03-27-2017, 08:58 PM
Do you by any chance have a remote handle on your grey tank drain. If not check to insure that the blade/gate in the drain valve is actually moving and not stuck and just the handle and the rod are moving.
TST Tire Monitors
2 100W solar panels
03-27-2017, 09:12 PM
If you can remove the drain cover, you could try a Cobra Plastic Drain Snake and see it you can pull anything out with it. It would not damage any of the pluming lines.
https://www.lowes.com/pd/Cobra-Plast...tick/999908745
03-27-2017, 09:25 PM
I had a 2009 Freedom Express and the grey always drained very slowly. Eventually I took the drain valve apart and found they had left the seal disks in it. The plastic disks prevent the rubber seals from deforming during shipment and are supposed to be removed when the valve is installed.
2009 FreeLander - Retired
2015 FR3 30DS - Retired
2023 Sunseeker 2440DS
Towing 2016 Chevy Sonic LT
Thanks flybob I will check that
03-27-2017, 09:26 PM
I will check that. It's under warranty so I am gonna take it over in the morning and let them figure it out. Thanks for all the tips.
03-27-2017, 09:46 PM
Scoundrel
Please report back of what was found...
