Old 03-06-2013, 11:11 AM   #1
Denver, CO
garbonz's Avatar
Water capacity
I sanitized my new camper and noticed that the 44 gal tanks appears to not hold that much. I haven't checked precisely, but I only filled my 45 gal bladder tank about 2/3 full and it overflowed the fresh water tank pretty fast. I'm thinking maybe it holds less than 35, if that.
Anyone have a similar issue?
2017 Fuse 23T
Old 03-06-2013, 11:23 AM   #2
daydreaming about camping
jeeplj8's Avatar
yes. Mine will hit the overflow at about the 2/3 mark. I cannot get more than 2/3 into it. Dealer says this is normal...
I am actually planning to try and re-route the overflow this spring.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 03-06-2013, 11:24 AM   #3
Fulltime family RVer
Is it really a 44 gallon tank? Or is it 44 MINUS whatever the water heater holds? I think I've read that some manufacturers advertise water capacities, but include the water heater in their advertised amounts. Not sure if your RV/manufacturer does or doesn't. But, just a thought...
Old 03-06-2013, 11:28 AM   #4
Witch Doctor's Avatar
I also think they included the H/W tank in mine...
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-06-2013, 11:29 AM   #5
Campingnut's Avatar
All the trailers that I have had the fresh water capacity includes the hot water tank capacity.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 03-07-2013, 07:17 AM   #6
I had a similar issue with my 2013 Solera 24R. I was told by the factory that FR reserves the right to change specifications without notice.
You should not expect your actual tank capacities to match any written specifications or the brochure. You get what you get.
My 35 gallon fresh tank only holds 30 gallons. They just printed 350,000 brochures so they won't change the brochure until the current supply runs out.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 03-07-2013, 02:32 PM   #7
I agree with you, but they also add the water in the H/W tank for cap. which would put you at 36 gals full. But I could be wrong wouldn't be the first time.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-07-2013, 07:52 PM   #8
As I recall, I was told in a thread here that FR does not include the water heater capacity. They go by the number stamped on the tank and in my case the supplier did not use an accurate number. FR does not test the accuracy of capacity claims by its suppliers. fwiw, it took me about 15 minutes to verify that the stated capacity was not accurate. One would think that over the life of the Solera product line that someone at FR would have tested it at least once.
Old 03-08-2013, 11:25 AM   #9
I surely would not doubt that, I can only say what I was told. But I have a trend to be a sucker at times....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-08-2013, 11:49 AM   #10
MY in-laws bought a brand new Hemisphere 5th that stated it had a 40 gallon tank. My brother in-law tested it out, he could only get 24 gallons. After months of arguing with dealer and FR, FR finally agreed to fix it. They are supposed to be installing a nice "big tank" for them. What that means my brother in-law is not sure but will find out when they get their 5th back from FR.
custer01 is offline   Reply With Quote
