Old 02-25-2015, 01:08 PM   #1
jmcrae3891's Avatar
Water connections
I bought this trailer used, and it didn't come with the hose for the outdoor water connection. It looks like a pressure washer hose connection.
Has anybody run across this or know where I can get one? Thanks!Click image for larger version
Name:	ImageUploadedByForest River Forums1424891279.257873.jpg
Name:	ImageUploadedByForest River Forums1424891294.339544.jpg
2003 Dodge Ram QC 2500 4x4
2005 Nissan Altima
2011 Forest River Lacrosse 301RLS
jmcrae3891 is offline   Reply With Quote
Old 02-25-2015, 01:19 PM   #2
Ashley's Avatar
2005 Nissan Altima
Here are a couple links to what mine has on it. Not advocating this is what or where you should buy it.
D And W Inc. SA-HOSE-15-ASY 15 Foot Coil Hose Assembly With Brass Insert | MFG# SA-HOSE-15-ASY | 22027 | Hanna Trailer Supply Oak Creek, Wisconsin
http://www.dyersonline.com/dandw-15-...h-sprayer.html
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 02-25-2015, 03:24 PM   #3
jmcrae3891's Avatar
Thanks! Hard to look for something you don't know the name of.
2005 Nissan Altima
Old 02-25-2015, 03:43 PM   #4
Ashley's Avatar
2005 Nissan Altima
Your Welcome, and you're right about searching for stuff sometimes when everyone calls stuff something different.
Just a "Tip" too on connecting the male quick connect fitting into the female coupler. If it hasn't been used in a while you may have to take a flat tip screwdriver and depress the check valve that is inside the female coupler. It will stick and no matter how hard you try and press the male end of the hose into it you can not get it to go deep enough to lock in place. Trust me, I learned the hard way after fighting with it one day for about half an hour. Barely even touched it with the screwdriver and it popped free. One of those learning experiences you just don't forget.
Good Luck with your Lacrosse, We love ours!!!!
Old 03-05-2015, 09:13 PM   #5
tmhyer's Avatar
Looks more like your outside shower
tmhyer is offline   Reply With Quote
Old 03-05-2015, 09:22 PM   #6
trbomax's Avatar
That IS the outside shower.The tank fill is above it to the left. I have an adapter for the water hose that has a ball valve and a small 1/2" hose about 12" long that you can actually run down inside the filler. You want the plastic ball valve so you do not over pressurize the tank when it starts to fill up.
trbomax is offline   Reply With Quote
Old 03-15-2015, 09:49 AM   #7
D&W Inc. (Spray Port manufacturer) also sells the quick connect adapter to use with a normal hose. $6.00 each on their site and free shipping.
ksignoles is offline   Reply With Quote
Old 03-15-2015, 10:58 AM   #8
jmcrae3891's Avatar
Nice to know. I will probably never use the outside shower. Other than being covered in mud and want to wash off before going inside, I cant think of a reason to use it.
2005 Nissan Altima
Old 03-16-2015, 01:39 PM   #9
2005 Nissan Altima
Different strokes for different folks. I use the outside shower as an outside water spigot - with hot water available no less! Comes in handy washing dishes at the picnic table as a source of hot water for washing and rinsing. No more in and out for hot water.
But we generally limit inside activity to sleeping and waiting out rain showers.
Fred W
2014 Rockwood A122
2008 Hyundai Entourage (minivan)
Old 03-16-2015, 01:43 PM   #10
Fulltime family RVer
I like that. I may pick one up for our outside sink- the coil hoses don't ever reach our fire pits.
water, water connection
